Need Help! PSU vs X1950Pro : other suggestions PLEASE
  • Graphics Cards
  • Graphics
September 26, 2007 12:24:34 AM
Here's my problem(I really need help I'm lost):
I want to replace the onboard video card in my new system:
Asus M2A-VM
X2 4600+ EE 65W
2X1GB OCZ Gold 2.1V
The best card I found (Max at about 150$ CND) is a SAPPHIRE X1950 PRO : http://www.ncix.com/products/index.php?sku=21246&vpn=11...
I heard this card had problems with some PSU - requirements: 30A on +12V. Mine is : http://www.startech.com/Product/PhotoGallery.aspx?Produ... . There are two 12V rails (17A and 16A) on that PSU. Can we say 17A+16A=33A??? Would this card work with my system??
I don't want to change de PSU, do you have any suggestions? The more I read on PSU and Video Cards, the more I'm lost and I don't know what to do.
Your help would be really appreciated
Thank you
More about : psu x1950pro suggestions
September 26, 2007 12:50:59 AM
No, what you need to do is take the watts supplied to the +12v rails and divide that by 12. In your case it's 360/12=30. Good news! You made it!
Those recommendations are also made for fully loaded systems. There are people here running that card with 25amps or so. You should be ok.
September 26, 2007 8:28:41 AM
I run it wil 22 amps :p
that psu should technically be fine.
