First Computer------Im not sure if this will all work plz help!!!
Last response: in Systems
That doesn't work :) . If you like you could save it as some name and let us know the name of it so we can look it up. If you have aim or yahoo or msn, let me know. You can msg me at anytime and I'll be glad to help you out with everything :)
Related ressources
Well I think you need more memory, like 2GB to run a healthy computer these days. 1 may slow down your system by a lot. Also you might want a bigger PSU, at least 430-450W. For the card, if you can go for the X1950Pro, it's better than the GT and around the same price :) .
Also you can get a little cheaper Motherboard, that would be just as good. Unless you are looking to do Crossfire in the future.
MSI K9AG Neo2-Digital or GIGABYTE GA-M61P-S3. Those are both really good cheaper boards you can use :)
Well i upgraded to the EVGA 512-P2-N773-AR GeForce 8600GTS 512MB 128-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card - Retail
i want dule moniter support if i got a MSI RX1550-TD128EH Radeon X1550 Support up to 512MB (128MB onboard) 64-bit GDDR2 PCI Express x16 Video Card - Retail cheap little card could i use dule monters
It depends on what you want to do. If you want to game, I would go for the X1950Pro, its better than the 8600GTS. If you don't need any gaming, you could get an 8600GT for cheaper. It supports dual monitors.
Ask the community
