Tom's Hardware > Forum > Overclocking > General Discussions > Increase graphics card fan speed problem
Forum Overclocking : General Discussions - Increase graphics card fan speed problem
hey I have been in some sort of confusion....I am planning to invest on a 8800GT but i heard that sometimes due to overheating the card causes system to crash. now after going through loads of review i have found out that the card comes with a default fan setting of 30% or something and in order to prevent the crashing i must increase the fan speed to 60%. Ok that is all fine but that is where the real problem lies...i heard from source that increasing the fan speed can kill the fan of the grpahics card...so i am very confused over this cuz i cant afford a zalman coolong fan ATM. Any solutions
Thanks
Francis 07
Sponsored Links
I recommend downloading rivatuner from 3dguru.com. It's a great utility for overclocking, setting fan speeds and monitoring gpu temps. Link:
http://downloads.guru3d.com/download.php?det=163
This tool will allow you to set up a sort of stepping function on your fan. Meaning that the speed of the fan will increase as the need for cooling increases using temperature points to activate different fan speeds. So, your fan can idle at whatever speed you are comfortable with and will increase speed under stress in order to keep your gpu temp down.
The guide for setting up fan profiles is here:
http://www.guru3d.com/article/article/449/
Hope this helps, and good luck.
------------------------------ AMD X2 6000+/ GA-M61P-S3 Mobo/ 2 GB Patriot PC2-6400/ 160 GB WDC HDD/ Sapphire X1950XT/ LG DVD RW/ Enermax Noisetaker 600w
Reply to KekaiGenkai
There are 736 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
