Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > evga 680i graphics power 3?
Forum Motherboards & Memory : General Motherboard - evga 680i graphics power 3?
On my new evga motherboard, there is a plug called power 3 for supplying power to the graphics card. However, my evga 8800 gts has a seperate 6 pin power input on the car itself. DO I need to use both of these plugs? Or do I just disregard the one on my mother board since my card has the power on it?
The instructions are are very unclear on this.
Thanks
MAtthew
Sponsored Links
Thats called the "EZ plug-power SLI" or 4pin AUX power connection to use in SLI setup.
It's suppose to ensure that both PCI-Express cards receive optimal power when they don't have the additional molex/PCI-E power connectors.And if using a 20pin power supply connection instead of the now standard 24pin.
Reply to ivanski
so should i run power to both the pwr 3 on th e mother board and the 6 pin power on the graphics card then?
Reply to mtstans
Only if you have older cards like 6800's that dont have 6 pin molex power connection.So in your case noooooo
Reply to ivanski
so just the 6 pin on the card and nothing to the power 3 correct?
Reply to mtstans
There are 1020 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
