I have the following configuration:
MOBO: ASUS P5VDC-Mx
Intel pentium D 2.8Ghz/fsb 800
DIMM Kingmax 2x512mb 800Mhz DDR2 (i know the mobo doesnt support 800mhz but i see no prob in this)
VIDEO: Sapphire radeon 9600pro 256mb/128
HDD: WD 250GB SATA II, MAXTOR 40GB IDE
600W Power supply atx
The problem is the fallowing... after i install windows (xp pro sp2) my system restarts without blue-screen.After that the sistem gets stable for a short time (5-10 minutes) and then another restart. But now i see that it only restarts when i try different program installations or when i play a game.for instance im running windows without any restart for about 40 minutes.
What should i do cause im trying to solve this problem for a long time. any suggestion is appreciated. thx in advance!
MOBO: ASUS P5VDC-Mx
