External storage help
  • External Storage
  • Storage
Last response: in Storage
February 16, 2008 6:05:55 PM
I am looking for external storage to store photos on only. Any suggestions? Thanks.
More about : external storage
February 16, 2008 9:29:22 PM
Suggest you assemble it yourself. If anything happens, you're not getting a connection or recognition, can just pull the drive and install it, you know the quality of the drive, and can always upgrade the drive. eSATA is the faster connection and most cases with an eSATA connection comes with a card. But if it's just backup and then a USB connection would work, all cases come with USB, which you want because you can connect to any computer. Get a case with internal SATA connection Something like this would work. As for the hdd, Seagates are good or WD but I'd probably stay away from Maxtor. Best to get as big as you can afford and makes sense.
http://www.newegg.com/product/product.asp?item=N82E1681...
