Hey I have an eVGA 320Mb in Vista Home Premium 1680 x 1050 resolution (stock at the moment... waiting on Rivatuner 2.05 ) and I have a problem playing some maps at full detail without getting some weird FPS but huge FPS hits (~30-40 FPS) around some areas in the map De_dust2. I haven't tried it out on HL2 but I think I will tonight. I believe it could be a problem of running out of VRAM or faulty VRAM because Overclocking the core and the memory did not seem to help with this problem.
Ive got the same card/cpu/ram and it fooly SMASHES HL2.
Maybe a driver issue?
Maybe vista issue?
Uninstall/reinstall etc. Ive also heard atl tab and do good things sometimes.
Re HL2... giving it another bash ATM. Set v-sync on, limits fps to 60.
However if i do a quick load it halves to 30 If i load again it fixes.
Odd. Otherwise maps like dust etc should get smashed by an 8800.
Lack of vram is not an issue imho.
It is definitely not a driver issue, I've installed multiple drivers (including beta ones) and they all have the same problem. I'm hoping it's either a map issue or a game issue or a fixable vista issue. I don't really want to reinstall Vista =/. 'Retry' ing the server seems to help a bit but the fps drops are still there around pit and in T spawn.
Also sometimes the FPS drop(it stays around 20-25 FPS or so) holds constant for other parts in the map and then suddenly goes away when i get to certain places, but not always such as around 'side' and in 'middle'.
I don't know if it is possible to reinstall a particular map or if I should just reinstall the entire game, Office seems to work just fine, Haven't tried a whole lot of other maps.
On a side note I'm only able to overclock my VRAM to about 850 or so or else I start to get artifacts. Core Clocks fine. I'm definitely going to step-up one of these days though. Might as well use the feature if I have it, right?
Anyway, I'll post my problem on the Steam forums see if i can get anything there.
Sounds like it might be the dreaded 8800 slowdown bug. It is a texture management problem that happens on all 8 series cards, but the 320MB version gets hit hard by it because of its lack of VRAM. I have an eVGA 320MB 8800gts and I was having this problem like crazy. I almost sent it back, but the newest drivers have fixed it (although only in DX9) for me.
Well I think, I'll just throw money at the problem and step-up to a GTS 640Mb. Its only about a $50 step-up and my current GPU's VRAM sucks at overclocking anyway (can only get up to ~860) which is a huge downer for me . Or i might even get a GTX but I'm leaning towards the GTS
I agree that you should get a much better OC on your VRAM than that. I'm at 950MHz and it's not even hot. I've gone up to Ultra speeds but I have no need for that so I stick with my cool 950.
As for the step-up, if you wait a bit longer you may be pleasantly surprised by g92 in November. If you don't feel like waiting then I see no harm in upgrading to a GTX
u geting this same issues in SP mode? if not its server side. If so...are you making sure that in game resolution and desktop res are matched- i had lag spikes on 2142 when not matched....and just an fyi- I have a 640 and it crushes everything atm- ran bioshock demo like a champ as well.
good luck
Sorry, I wasn't very clear I said "an extra $100" because I would like to step-up to an 8800GTX (its not actually a $100 its actually about 250 ) Vs. a GTS 640 but I don't know if it would be worth spending that extra $250 dollars so I'm hoping I come across some cash sooner or later. Or I might sell my card on ebay and wait for the next wave of cards, be it 8900 Series or 9800 series
