Tom's Hardware > Forum > Overclocking > CPUs > CPU + RAM timings problem
Forum Overclocking : CPUs - CPU + RAM timings problem
I managed to boot into windows with 1.475 v with 3.6ghz on a e6750.
But i have to make my ram timing to 5 5 5 15 to boot up.
If i set my ram to 4 4 4 12, it won't even boot up.
Is there a workaround for this? My ram volts is set to +0.3v.
Sponsored Links
I'll be honost, the lowered timings will show no real world performence increase that is noticable. Since your already overvolting by quite a bit also and it's still not doing cas 4 just lower your ddrvoltages back down as well as the timings to cas 5, it will even let your cpu run cooler, I noticed that when I changed my 2.2V Cas 4 ram to 1.9V cas 5. My 3dmark06 scores didnt even change, and thats pure synthetics, plus like I said the cpu ran much cooler during idle.
------------------------------ The computer allows you to make mistakes faster than any other invention, with the possible exception of handguns and tequila- Mitch Ratcliffe
Reply to bildo123
There are 579 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
