Hey, my newly built machine will occasionally power down while I'm using it. It doesn't seem to correlate too strongly with any particular event/program.
The symptoms are similar to CPU overheating, but Core Temp reads both my cores in the 20-40C range almost at all times - even right before cutting power. I also just did an application of ArcticSilver5 to replace the manufacturer's thermal paste.
My second guess is that my RAM is may be a fault. I'm running a supposedly picky MoBo with memory not officially tested . . . I've heard there are workarounds in the BIOS settings, but I haven't done anything as I'm not entirely sure the RAM is causing the problem.
Here are some specs:
O/S- Windows Vista 32
MoBo- ASUS M2N-SLI Deluxe
CPU- AMD X2 4800 Brisbane
GPU- EVGA 7900 GS KO
RAM- 1GX2 Patriot PC6400 800MHz 4-4-4-12
If you need more intel, let me know . . . thanks
