Yea what Gravemind123 said but also what is the rest of the system like i mean are you planning to run DX10 or aer you using XP for the forseable future?
Mactronix
thanx for nice reply...
*specially (akhilles) thanx for benchmark..its really gr8 *(Gravemind123) yup i want 2 buy a card for Gaming..!
*(mactronix) m also planning toi run DX10 on my sys? which 1 one this card mactronix support it?
one more Question guys: HIS [Hightech Information System Limited]graphics card is reliable or better?
Can you tell us the rest of your system?
8500GT is a DX10 card but bad for gaming.
1650 pro is better for games but is DX9,also you wont need 512 mb 256mb is enough and cheaper.and a Gddr3 card would be better if you can find one.
You must have Vista not XP to use DX10.
My own opinion is
ATI X1650XT or Nvidea 7600GT minimum must be GDDR3 for DX9 gaming
Nvidea 8600GTS or ATI 2600XT GDDR3/GDDR4 800Mhz for DX10 gaming.
HIS are a good card as are XFX check warranties and what else you get in the box with the card
Mactronix
Thanx Mactronix for detail reply...!
my frnd m'nt afford those card...! can b go for this 1:
SAPPHIRE RADEON™ X1650 PRO core (600MHz)
CrossFire™ Support
256MB DDR2/GDDR3 Onboard Memory (1400MHz)
Microsoft® DirectX® 9.0 Shader Model 3.0
Microsoft® Windows Vista™ Ready
What about this card?
And which vendor is better
NVIDIA(XFX vs inno3D) vs ATI (SAPPHIRE vs HIS)
can u rate the above graphics Vendors
CrossFire™ Support
thanx again...!
I am more than willing to help but can not really recommend a card if i do not know what games you want to use it to play and what the rest of your system is.
If you are happy that you want a card like this one and are just worried which one to get then yes the card you asked about is one of the better ones but please make sure that if you have the option you get the GDDR3 one.
XFX is a better known make and i think they have a better warranty than Inno 3D
There is not a lot between Sapphire and HIS in my opinion i would be happy with either.
Mactronix
I had Inno3d Card way back in 2005, Geforce 2... Wel it malfunctioned (due to burning down by overheating) only after one and a half years. The one year warranty was gone so it could only had to be repaired but it couldnt so there goes Rs 9800 ($100) down the drain.... This time around I hope to buy 9800GT but I will go for XFX and hope it is more reliable than the mediocre Inno 3d...
If any one knows what precautions I should take so that the new card XFX doesnt burndown by overheating so quickly please do tell. Does playing games 4hrs a day is a cause of malfunctioning.... I swear if my new card also malfunctions after just one years I am never going to buy an additional to motherboard 3d card ever.....
PS Does spikes, overvoltage and no grouding of pc causes a 3d card to burn down or malfunction????
