Hi, I'm new to using Raid and even newer here.
I have a small server that is using an LSI MegaRAID SAS 8308ELP raid card.
This was set up to run 2X80gb disks (raid1) for the O/S.
this all works fine with no problems and very good performance.
I recently added 2XSamsung 500Gb disks, also raid1.
These worked for several days without problem.
The server was restarted and the LSI card reported that the disk installation had failed.
I thought "failed disk". However, I can install each disk as a single disk without problem and run them on any channel.
However, as soon as I connect both disks to the card, it reports a badconf error on a disk (this seems to be random and doesn't seem to follow either a disk or a channel).
Plugging both disks directly onto the server motherboard means Windows sees both disks OK
I know the disks are OK and the card is OK - my O/S is running on it with out problems.
Anyone got any ideas on what's going on?
A friend suggested corrupted "metadata" - I don't know what this is
