News
Toshiba and NEC develop new fast, high density MRAM
Published on February 07, 2006
Toshiba and NEC today announced that they have developed a magnetoresistive random access memory (MRAM) that combines the highest density with the fastest read and write speed yet achieved. Read more
Sandisk, Pretec unveil speedy 4 GB and 8 GB CF cards
Published on February 27, 2006
Sandisk has added an 8 GB version to its Extreme III line of Compact Flash (CF) cards. Read more
Intel, Micron Sample 200 MB/s Flash Memory
Published on February 01, 2008
Intel and Micron are first to announce NAND flash memory chips using the new high-speed interface specified by the Open NAND Flash Interface (ONFI) group: The new memory promises five times the read/write performance of flash memory devices available on the market today. Read more
Intel enters the flash drive business
Published on March 12, 2007
Intel has entered the flash drive business by announcing its Z-U130 flash drive. Using NAND flash technology, the drive will come in 1, 2, 4 and 8 GB sizes and use a USB connector. Intel claims the drive will be speedy and will read at 28 MB/sec and write at 20 MB/sec. Read more
Latest Reviews & Articles
System Builder Marathon: $500 Gaming PC
Published on October 30, 2008
On this, the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
Tom's SBM: The $1,500 Mainstream PC
Published on October 29, 2008
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
System Builder Marathon: The $4,500 Super PC
Published on October 28, 2008
This month's System Builder Marathon spreads the system prices out even further to $4,500, $1,500, and $500. Is today’s $4,500 system really worth three times as much as an upper-mainstream performance machine? Read more
Can Your Old Athlon 64 Still Game?
Published on October 24, 2008
We'd all love to upgrade every time a new piece of gaming hardware drops, but that's an expensive proposition. You think your Athlon 64 system is fairly quick--any chance a simple graphics upgrade can bring it up speed? We're aiming to find out. Read more
  Tom's Hardware Forums » Storage » NAS/RAID & Technologies » RAID 5 write speed help
Word :   Username :
Bottom
Author
 Thread : RAID 5 write speed help
Profile: stranger
More Information
I have been trying to figure out if it is possible to speeds up my file transfers to my server. Here are the specs of the server:
Pentium D 805
2 GB DDR2-533
ECS P4M800PRO-M v2
LSI MegaRAID 150-6 (running in a 32bit PCI slot)
3 X 500GB Hard Drives in RAID 5
I get about 11MB/s when writing files to the server through a USB hard drive (write back enabled). Is this considered normal write speeds for RAID 5? I know I am running some old/cheap hardware, but I was expecting the write speeds to be higher. I figure the issue is probably either the motherboard or the RAID card. What would be the best way to increase the write speeds? New raid card? New motherboard?
Related Product
BAM!
Profile: Faithful Poster
More Information
First of all... the limitation here would be the USB drive, so i wouldnt be concerned for your array... if you get HDTach you could do some testing to get a better figure.
Have you got USB2.0 harddrive? I see your mobo does but dont know about external drive... drivers maybe an issue here too try maybe updating chipset drivers from ECS website.
Although the RAID card will be somewhat limited by the 32Bit PCI slot it would NOT limit it to 11mb/s
"This thread made me strap on my lolerskates and head for my roflcopter."
Profile: stranger
More Information
It is a USB 2.0 drive, but I know it's not the issue. I can read and write to it much faster on any other computer. Also I got a similar speed when I transferred data from an SATA drive to the RAID array.
Message edited by brad28304 on 02-22-2008 at 03:34:00 AM
Profile: stranger
More Information
Hi
Please assess whether you have the latest driver loaded, expereinced a similar problem on a Raid PCI card. After update, I could not believe the difference.
Regards
Profile: stranger
More Information
Well I am running ubuntu 7.10 I just put the CD in and installed. I guess its running the default ubuntu 7.10 drivers. I am not sure how you check.
Profile: stranger
More Information
Hi
Unfortunately unable to help, noob on Linux. This was an experience on Winodws XP Pro. I am sure you may be able to get help in the O/S section of the forum.
Regards
Druedd
Sniper
Profile: Forum Fixture
More Information
Pentium D 805
2 GB DDR2-533
ECS P4M800PRO-M v2
Thats most likely the problem. Imo, ECS boards have a tendency to have a lot of problems. It could also be your RAM, which is limited to 533Mhz.
E2180 @3.2Ghz + P35DS3L +8400GS (700/475 OC)
http://farm4.static.flickr.com/3268/2588429538_b3c41b29c3.jpg
Profile: stranger
More Information
Ok, let’s just say my motherboard is the problem and I replace it. Would one that has a 64bit PCI (PCI-X?) bus be worth it? Or should I just stick to a 32 bit one (much more common). Any recommendations? Also what kind of write speeds should I be getting roughly?
Google Ads
