News
Nation's energy grid could power almost 185 million electric cars
Published on December 11, 2006
A Department of Energy report shows that the U.S. energy grid could support up to 185 million electric or hybrid cars. The department believes a switch to the newer vehicles would clean up the environment and could even improve our national security situation by reducing the need for imported oil. Read more
Enermax Readies Modular 1000 W Power Supply
Published on June 08, 2006
Power supply specialist Enermax is showcasing a very special solution at Computex: Galaxy is its latest top-of-the-line 1000 W PSU. It was designed to power the most sophisticated computer systems. Read more
New Yahoo Messenger supports plug-ins and more contacts
Published on June 21, 2006
The instant messaging war is starting to heat up again as Yahoo has released a brand new beta of its popular Yahoo Messenger application. Read more
Asustek Launches Power Efficient Server Board
Published on December 21, 2007
Asustek Computer has announced the DSEB-D16 series server board, a 45nm Intel Xeon 5400/5200 processor ready platform, which the company claims is capable of 90%+ power efficiency. Read more
Latest Reviews & Articles
System Builder Marathon: Performance & Value
Published on October 31, 2008
Three dramatically different builds face off in a show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
System Builder Marathon: $500 Gaming PC
Published on October 30, 2008
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
Tom's SBM: The $1,500 Mainstream PC
Published on October 29, 2008
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
System Builder Marathon: The $4,500 Super PC
Published on October 28, 2008
This month's System Builder Marathon spreads the system prices out even further to $4,500, $1,500, and $500. Is today’s $4,500 system really worth three times as much as an upper-mainstream performance machine? Read more
  Tom's Hardware Forums » Motherboards & Memory » MSI-Microstar » MSI SLI P6N - CPU power plug
Word :   Username :
Bottom
Author
 Thread : MSI SLI P6N - CPU power plug
Profile: stranger
More Information
I have purchased this board and while putting it together.
I noticed the CPU power block has 8 pins.
Four are blocked off, only four are exposed.
My BIG power supply only has an 8 pin 12v block.
no four pin block for 12v.
Why are the left-most pins blocked off?
I had to use a smaller powersupply to get a 4-pin connector.
Can I just remove the cover on the MB?
http://www.msicomputer.com/product [...] m&class=mb
its the block at the bend of the heat-pipe.
Anyone know why it is capped off?
And if the cap can safely be removed?
Related Product
Profile: addict
More Information
There should be no problem connecting the 8 pin (2x4) connector. The "extra" 4 pins are required for some Hardware (ie Pentium D Extreme Processor and posiblily for SLI configurations. I have the Gigibyte 965-DQ6. Originally hade a PS with 4 Pin connector, the I swapped out my PSU and the new PSU had 8 Pin - I used it and had no Problems.
Reason it is capped is that if a 4 Pin connector is use, They do not want it plugged into the "Capped" portion as the computer would not boot leaving the person scratching their Head.
My manual leans toward using the 8 Pin if you have it, BUT if you only have the 4 Pin, And do not require the extra current then leave the cover inplace
Message edited by RetiredChief on 10-03-2007 at 07:13:53 PM
Profile: stranger
More Information
I contacted MSI support,
its OK to pop off the cap.
I checked the docs,
its all 12V on one side grd on the other.
I swapped powe supplies and all is well.
Thanks to all those who replied.
Google Ads
