Tom's Hardware > Forum > CPU & Components > Sound Cards > Realtek sound problem
Hi
I have an onborad realtek hd audio card with the latest drivers. The problem is wheever i try to play a game or watch a movie anything that has to do with sound. it throws on to desktop and I get constant messages about "jack has been plugged " & "jack has been unplugged".
I have tryed unplugged all cable's from the sound card. And i still get thrown on to desktop when trying to play a game or watch anything :fou:
any ideas?
Sponsored Links
Are you running the latest drivers? Download them from here.
-Wolf sends
------------------------------ System Specs:
Gigabyte EP43-UD3L Intel Core2Quad Q8400 8 Gig RAM
NVidia Geforce 8800GTS-640/Creative X-FI Extreme Music/Dual-Boot XP-64&Server2008
Reply to Wolfshadw
i have solved the problem
in sound options you have tou disable front pannel jack detection
Reply to Painkiller13
"in sound options you have tou disable front pannel jack detection"
Can you explain this more clearly? Where is this Sound Options you are referring to?
Reply to firstauthentics
- 1 +
I think the one Painkiller13 is referring to is the the realtek audio suite (I forget the name).
There is a option in there for auto jack-sensing
------------------------------ GA-X38-DS4 (BIOS F3)||E8400 C2D (3.6GHz)||2x 1Gb Crucial Ballistix DDR2-800 4-4-4-12||320Gb WD Caviar||2x 750Gb WD Caviar||Cooler Master Real Power Pro 750W||2x HD4870 512Mb(Crossfire)||HT Omega Striker 7.1
Reply to jay_l_a
it is in the i (information) down the bottom right in audio manager if you right click on the orange speaker in your task bar. at the bottom of the pop up window there is an option to "show information in icon bar" or something like that. click it. that will disable it. the annoying pop up shall never annoy you again.
Reply to it30rivers
There are 962 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
