Hi, Im in desperate need for advice on a new LCD Monitor, my old monitor died on me yesterday, and i have a project to finish by tommorow, I am looking for a high quality (reliable) monitor with a 1600x1200 rezolution(or something higher than 1280x1024, since i finally got good hardware for gaming), I was planing on getting a regular non wide screan monitor, but I could not find it anywhere, and my only choices I guess are :
SAMSUNG 204B-BK Black 20" 5ms DVI LCD Monitor:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001226
Samsung 22” Widescreen Monitor (226BW):
http://www.circuitcity.com/ssm/Samsung-22-Widescreen-Monitor-226BW/sem/rpsm/oid/170984/catOid/-12965/rpem/ccd/productDetail.do
ViewSonic 22" Widescreen Monitor (VX2235WM) :
http://www.circuitcity.com/ssm/ViewSonic-22-Widescreen-Monitor-VX2235WM/sem/rpsm/oid/162158/catOid/-12965/rpem/ccd/productDetail.do
I was planing on getting a regular monitor since it was 1600x1200, instead a widescrean monitor that has a 1680x1050 rezolution, .....why are wide screans better? why arent they?
Is a glosy screan better than a non gloss one?
Will i have issues with wide screan monitors in gaming? I heard some people do have some problems with wide screan monitors/gaming
Any imput would be much apprecieated, I honestly know nothing about monitors , which brand is good?, what to look for? (so far i know the rezolution, and the refresh rate, but the refresh rate on all widescreans i saw was only 60Hz, and i have been to 7 stores in the last 4 hours)
Thank you for all the imput, much oblidged(and needed)
