Power related problem?
Word :   Username :
Bottom
Author
 Thread : Power related problem?
Profile: stranger
More Information
Greetings; This is my first post on this forum, so I'll be as concise as possible. My system specs are as follows:
Coolermaster Centurion 5 case
Antec sp 500 PSU
Corsair twin x ddr 400 memory-2 x 512meg
Asus A8n-Sli Deluxe MB
Opteron 170 cpu
Asus Geforce 7600 gs video
DVD-rw drive and floppy drive/card reader combo
I built this system and have had it running well for about 1.5 years and recently after cleaning (blowing dust out of case), My system failed to start up. I checked reviews for psu (which where very positive at time of purchase) from Newegg, and I discovered that quite a few of these had failed within the same time period as my purchase. I contacted Antec and they informed me that they had discontinued that model, and much to thier credit they promptly sent a replacement. The replacement is a Neo HE 500 watt.
Ok, so I replaced the psu and started my system up with no problem and everything seemed fine. I went into bios and set it up as it was previously, (overclocked to 2.8 ghz @ 1.4 volts prime stable). Everything seemed fine and I ran some bench marks and did some work (estimating and bookeeping) the rest of the day and shut it down for the evening. Next morning, I pushed the power button and lights came on briefly and fans started to turn, then shutdown immediately. I tried this several times (5 or 6) and finally it stayed on. However, when posting, it said "checksum error, defaults loaded". I continued to bootup at default settings and everything was fine albeit much slower. I then restarted and set up bios again as I had it previously and continued bootup and again, no problems. I seem to be able to restart at any time and it boots right into Windows with no problems, however the problem happens every time I shut it down completely and attempt to start up again, multiple times of pushing power button before system will power up completely and then it starts with "defaults loaded".
My question is could it be a problem with the new psu, the power switch or something else? I have checked all mb connections and reseated cards and memory. And why would it continue to load defaluts when finally staying powered up? Any ideas or suggestions would be greatly apprediated.
Related Product
Profile: newbie
More Information
bios battery perhaps...
Profile: nimble knuckle
More Information
Does this happen when the system is not overclocked?
Profile: stranger
More Information
Hello again;
I thought about the cmos battery, because when it loads defaults, the time and date go back to the original bios date. And in answer to the other response, i'm not sure about bootup when not overclocked. I will test that. Thanks for the ideas.
More Information
It could be the result of 'failed overclocking', which is not to say that you can't OC to 2.8, but if for some reason your voltage tweaks are not kicking in after a cold boot then you may not be able to hit the 2.8 until you have reset the tweaks. Just a thought.
Some MOBO will load defaults automatically after x number of failed boots. So maye a battery issue and maybe not.
Profile: stranger
More Information
Well it is definitely not cmos battery issue, and is not a failed overclock. I replaced the battery, and tried cold starting several times at default settings and the symptoms are still the same. It takes about 5 pushes of the power button for it to stay on. Once its on, it runs great and temps are between 37 and 40 for cpu. Anyone got any other ideas?
More Information
just saw your new post, any better?
Profile: newbie
More Information
i had run into similar problem long time back, i suppose it is due to the PSU, if that doesnt resolve then try flasing your bios. The resetting of bios can be attributed to CPU frequency.
Message edited by vivek on 09-28-2007 at 01:07:28 PM
Profile: stranger
More Information
Well, I have flashed my bios and no difference. I have left it running day and night so as not tax my power switch or psu trying repeatedly to get started. I am thinking I will contact Antec and see if they can give any help. Another possibly related problem is that when I try to run Pcmark 05 or 3dmark 03 they try to load and then my system restarts. I have run prime 95 and sp2004 and everything seems stable, even good temps under load. I am at a loss as to what to do next. I hate to have to take the psu out of my wife's computer just to see if it exhibits the sames with different psu, but that may have to be my next move.
Profile: newbie
More Information
I can understand your frustration & more so when you have a latest system and things go unexpectedly wrong, intriguing as to why only advanced users face intricate problems?? one thing is for sure be patient and things will fall into place. goahead and try out the PSU from your other system or get a cheap one just to test. Probably a component inside your PSU (like capacitor stuff) is not charging up after a system is turned off for a brief period.
do remeber to put a message after you have resolved. :hello:
Profile: Ancient Poster
More Information
Among the other things check that the Bios reset jumper is in the right place.
Google Ads
News
Nvidia Contract Makers In Taiwan Low-key Over Defective Chip Reports
Published on July 07, 2008
Nvidia's Taiwan-based graphics chip contract makers are being low-key after the US chip designer informed investors on July 3 that will take a charge of US$150-$200 million related to expenses stemming from issues discovered with die/packaging materials used in previous generation notebook products. Read more
ATI Catalyst drivers have a problem
Published on August 27, 2004
ATI has a problem in the latest Catalyst drivers. Read more
Xbox 360 component shipments to boost Foxlink and Ji-Haw revenues
Published on September 08, 2005
Foxlink (Cheng Uei Precision Industry) and Ji-Haw Industrial (JH) reported that they began shipping Xbox 360 related components to Microsoft in August, and they expect shipments of the related products to contribute significantly to their revenues in September. Read more
ASP for PC-related LCD panels to rebound in Q2
Published on February 24, 2006
Prices slide for PC-related LCD panels will ease in April or May, as demand will start picking up, according to DisplaySearch. Read more
Latest Reviews & Articles
Updated CPU Charts 2008: AMD Versus Intel
Published on October 01, 2008
The processor is the heart of your PC, and our updated charts for Q3 2008 show 54 of them competing in terms of performance. Using our updated suite of benchmarks, compare your favorite AMD and Intel CPUs after reading this introduction. Read more
Stalker: Clear Sky--Is Your System Ready?
Published on September 30, 2008
Thinking about picking up the latest update to Stalker, but not sure if your graphics subsystem can handle it? Hang on as we take you through a performance tour and demonstrate how the game has been prettied up. Read more
Part 4: Avivo HD vs. PureVideo HD
Published on September 29, 2008
The 780G chipset/Radeon HD 3200 and the MCP78S chipset/GeForce 8200 provide the first integrated graphics solutions that can accelerate Blu-ray playback. We dig deep into how well they work with high-quality Blu-ray 1080p video playback. Read more
Four GeForce 9600 GT Cards Compared
Published on September 26, 2008
Manufacturers really love the first Geforce 9. The graphic chip is fast, the cards are inexpensive, and some retailers offer more than ten variations. Read more
