Tom's Hardware > Forum > Homebuilt Systems > New System Build > beeping sound when first turn on new build..help please!!
Forum Homebuilt Systems : New System Build - beeping sound when first turn on new build..help please!!
hey i just recently got my new build put together and i first turned it on and there was a long beeping sound..is it a problem with ram placement? or what? anyhelp would be good thanks
Sponsored Links
Some mobo's don't like the SPD timings that come preprogramed on Ram, I know mine didn't. It would be helpful if you could add your spec's to your sig so we can help you better. Do you know what you Ram timings are? Also your mobo manual should have a beep code book that will tell you what the beeps mean.
Most of the time its just that most Ram these days use anywhere from 1.8-2.4 volts, thats what I'm guessing it is.
------------------------------ Intel C2D E6600 @ 3.2GHz * Asus P5E * 2x1 GB Crucial Ballistix Tracers * Raptor X * EVGA Geforce 8800GTX 768MB 651MHz/1525MHz/2100MHz * X-FI Fatal1ty Pro * Enermax Infiniti 720W PSU * Creative THX5.1 * Tuniq Tower 120
Silverstone TJ09 * Windows XP
Reply to systemlord
That is mostly a Memory error. Check compatibility and voltage in BIOS.
------------------------------ Q6600 G0 @ 3.7Ghz | Abit IP35 PRO Rev.1.1 | OCZ Plat. Rev.2 4Gb PC6400 | BFG 8800GTS 640Mb @ 650/1900 | Dell 2405FPW | WD 500Gb SATA II | Antec Nine Hundred | Logitech G7 & G15 | Tuniq Tower | Antec NeoPower 650W | Vista HP 64 SP1
Reply to plguzman
did you plug the power connector into your video card ?
Reply to chungdokwan
Yeah my specs are..
EVGA nForce 590 SLI
AMD Athlon X2 64 Dual Core 2.8Ghz
Corsair Dual Channel TWINX 2048MB PC6400 DDR2 800MHz E.P.P. Memory (2 x 1024)
EVGA GeForce 8800 GTS Superclocked 320MB GDDR3
x2 Seagate / Barracuda 7200RPM / 500GB
ThermalTake PurePower 600W
Reply to akgeek21
- 0 +
Try booting using 1 stick of RAM instead of 2. Change out the stick if it doesnt boot with the first stick you try.
Reply to WR2
alright thank you..so i there might be the chance ill have to install the second one after i get it all set up?
Reply to akgeek21
- 0 +
Yes. If you can boot up and run on 1GB in single channel mode you can try 2GB dual channel (in most motherboards thats one stick in each of the same colored slots.
If 1GB boots but 2GB dual channel does not - try 2GB in single channel mode. 1 stick side by side in the different colored slots.
Reply to WR2
alright thanks again i appreciate it
Reply to akgeek21
Just a though... I've got a ASUS mobo. it gives me a long moris code beep is the case has been "shifted" things have moved etc.
Also, it may be the cpu contact to coolant. I hate that beep....hate it.
These are just guesses, your the eyes of the operation.
Good luck.
Reply to defrostu
so the whole problem with the beeping was that i didnt plug the extra power supply in for my graphics card...the mobo didnt supply enough power alone for the board..
Reply to akgeek21
Sounds like you find the problem then, thats great!
Message edited by systemlord on 09-20-2007 at 12:13:24 AM
Reply to systemlord
There are 812 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
