I'm having some issues trying to get my new rig to run stable overclocked.
I've seen other people with same mobo / cpu clock 3.2 - 3.6ghz but I cannot get anywhere near what they can stable, so I'm thinking its my ram settings / voltage that seems to be the issue.
If anyone could help me, would be most appreciated. I've tried adding extra voltage to the CPU / RAM & FSB and can get it to boot to windows @ 400x9 and setting the memory to 1:1 ratio, but it locks up as soon as i put load on it, i.e Everest / 3DMark06
Below is the settings out of the bios (I've used CTRL + F1 to access the hidden options)
System Specs:
Q6600 G0 - Thermalright Ultra 120 Extreme
Gigabyte GA-X38-DQ6 Bios: F5h
2GB OCZ FlexXLC PC2 9200 1150mhz 5-5-5-18 2.3 Volts
Inno3D OC 8800GT 650 / 950
Cosair HX620 PSU
2x750GB Seagate SATA HDD
** Advanced BIOS Features **
HDD SMART Capability Enabled
Limit CPUID Max to 3 Disabled
No-execute Memory Protect Enabled
CPU Enhaned Halt (C1E) Disabled
CPU Thermal Monitor 2 (TM2) Disabled
CPU EIST Function Disabled
Virtualisation Technoogy Disabled
** MIT **
Robust Graphics Booster Auto
CPU Clock Ration 9x
CPU Frequency 2.4ghz (266)
CPU Host Clock Control Enabled
PCI Express Frequency Auto
CIA 2 Disabled
Performance Enhanced with: Standard
System Memory Multiplier (SPD) Auto
Memory Frequency - 1066 1066
DRAM Timing Selectable (SPD) Manual
** Standard Timing Control **
CAS Latency Time 5
DRAM RAS# to CAS# Delay 5
DRAM RAS# Precharge 5
Precharge delay (tRAS) 18
** Advanced Timing Control **
ACT to ACT Delay (tRRD) 4 Auto
Rank Write to READ Delay 4 Auto
Write to Precharge Delay 8 Auto
Refresh to ACT Delay 56 0
Read to Precharge Delay 4 Auto
Static tRead Value 4 Auto
Static tRead Phase Adjust 0 Auto
Command Rate (CMD) 2 Auto
** Clock Driving & Skew Control **
CPU/PCIEX Clock Driving Control 800mV
CPU Clock Skew Control Normal
(G)MCH Clock Skew Control Normal
** System Voltage Optimized **
System Voltage Control Auto
DDR2 OverVoltage Control Normal
PCI-E OverVoltage Control Normal
FSB OverVoltage Control Normal
(G)MCH OverVoltage Control Normal
MCH Reference Voltage Control Normal
DDR Reference Voltage Control Normal
DDR Termination Voltage Control Normal
CPU Voltage Control Normal
Normal CPU Vcore 1.28750v
System Specs:
Cosair HX620 PSU
** MIT **
CPU Clock Ration 9x
CIA 2 Disabled
CAS Latency Time 5
