Hi there,
This is my first post here so please be gentle
Title should be huge "difference" in temps btw
It's been a while since I have overclocked a CPU, as most of my machines have been shuttles or media centre's of late.
However I decided to build a new PC and opted for a E2180. I currently have it running stable at 3ghz (300x10) at 1.41v according to CPU-Z. I tried to bring this down lower but its not stable. At idle, when the CPU has dropped to 1800mhz, the latest version of CoreTemp is reporting my temps as 20/21 for each core. However, when I run Orthos, the voltage drops to 1.39v and the temps jump almost instantly to 50/51c! Now I know thats not insanely high, but should they be that much higher than at idle?
Just for some added info, my mainboard is the Gigabyte P35C-DS3R, and I have an Arctic Cooling Freezer 7 Pro running at 2500rpm all the time. I have taken this off an reseated it, but it makes no difference. Oh and the case is a Coolermaster CM690 with 3x 120mm intake fans lower down and 2x 120mm exhaust fans at the top. Even when the temps are up at 50 or so, the air coming out of the back is not even warm and the heat pipes/fins of the Freezer Pro are cool to the touch.
Is this normal or should I be looking for problems here?
Thanks in advance for any help or advice.
Nathan
Nathan
