Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Many errors someone please look and help
Forum Homebuilt Systems : General Homebuilt - Many errors someone please look and help
I have had my system acting up for awhile now and I keep getting corruption errors. I go to download Nero Trial and when i try to execute it, it tells me the file is corrupt. I go to download stuff on uTorrent and i get corruption errors too when decompressing the rar archives. I also get problems in Steam for playing CSS it tries to validate game files and then goes to launch the game and crashes. I had terrible problems at Showdownlan 2007 in Indianapolis this past weekend and figured it was hard drive errors i was running raid 0 with 2 80gb sata2 seagate barracuda drives, now i reformatted to one and still same errors. I swapped my buddies ram out for mine and it worked for the lan but i have not had time to try more with other's ram so i ran hot cpu tester pro 4 and i have the logs from it that i was wanting someone to take a look at and see what could be the problem. I am getting memory cells do not match on both cores of the cpu the data is bumped up some values and also i had a quicksort checksums do not match error. On top of other cpu and memory errors it has. Below is my log thus far.
000000| 0000 00000760 Sep, 18 - 16:32:02 | Startig Hot CPU Tester Pro 4.3
000001| 1012 00000760 Sep, 18 - 16:32:02 | Initializing DefectTrack Engine version 2.2.0
000002| 1010 00000760 Sep, 18 - 16:32:02 | Loading options...
000003| 1011 00000760 Sep, 18 - 16:32:02 | Reading system info...
000004| 0000 00000760 Sep, 18 - 16:32:04 | CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 3800+
000005| 0000 00000760 Sep, 18 - 16:32:04 | Speed: 2008MHz
000006| 0005 00000760 Sep, 18 - 16:32:04 | -1
000007| 0005 00000760 Sep, 18 - 16:32:04 | 64
000008| 0005 00000760 Sep, 18 - 16:32:04 | 64
000009| 0000 00000760 Sep, 18 - 16:32:04 | L1 Cache Size: 128KB
000010| 0000 00000760 Sep, 18 - 16:32:04 | L2 Cache Size: 512KB
000011| 0000 00000760 Sep, 18 - 16:32:04 | L3 Cache Size: -1KB
000012| 0000 00000760 Sep, 18 - 16:32:04 | Hyper-Threading: FALSE
000013| 0000 00000760 Sep, 18 - 16:32:04 | SMP: TRUE
000014| 0000 00000760 Sep, 18 - 16:32:04 | Scanning SMBIOS...
000015| 0000 00000760 Sep, 18 - 16:32:04 | BIOS Vendor: Phoenix Technologies, LTD
000016| 0000 00000760 Sep, 18 - 16:32:04 | Manufacturer ID:
000017| 0000 00000760 Sep, 18 - 16:32:04 | Produce Name: NF-CK804
000018| 0000 00000760 Sep, 18 - 16:32:04 | Motherboard: NF-CK804
000019| 0000 00000760 Sep, 18 - 16:32:04 | Total Physical Memory: 1073197056 bytes
000020| 0000 00000760 Sep, 18 - 16:32:04 | Availabe Physical Memory: 692617216 bytes
000021| 0000 00000760 Sep, 18 - 16:32:04 | Total Virtual Memory: 2147352576 bytes
000022| 0000 00000760 Sep, 18 - 16:32:04 | Availabe Virtual Memory: 2105331712 bytes
000023| 0000 00000760 Sep, 18 - 16:32:04 | Operating System: Windows XP Professional Service Pack 2
000024| 0156 00000760 Sep, 18 - 16:32:04 | Setting Process Priority...
000025| 1111 00000760 Sep, 18 - 16:32:07 | Diagnostic has started
000026| 1112 00000760 Sep, 18 - 16:32:07 | Test Duration: 06:00:00
000027| 1113 00000760 Sep, 18 - 16:32:07 | Diagnostic Method: Sequential
000028| 1114 00000760 Sep, 18 - 16:32:07 | Error Handling: Ignore and Continue
000029| 1115 00000760 Sep, 18 - 16:32:07 | Hyper-Threading: Disabled
000030| 0010 00000760 Sep, 18 - 16:32:07 | -Complex Matrix : Enabled
000031| 0011 00000760 Sep, 18 - 16:32:07 | --Thread Priority: THREAD_PRIORITY_NORMAL
000032| 0011 00000760 Sep, 18 - 16:32:07 | --Matrix Size: 3,000x3,000
000033| 0011 00000760 Sep, 18 - 16:32:07 | --Matrix Data Type: Double
000034| 0010 00000760 Sep, 18 - 16:32:07 | -Calculating Pi : Enabled
000035| 0011 00000760 Sep, 18 - 16:32:07 | --Thread Priority: THREAD_PRIORITY_NORMAL
000036| 0011 00000760 Sep, 18 - 16:32:07 | --Pi Iterations: 10,000
000037| 0010 00000760 Sep, 18 - 16:32:07 | -Sorting Algorithms : Enabled
000038| 0011 00000760 Sep, 18 - 16:32:07 | --Thread Priority: THREAD_PRIORITY_NORMAL
000039| 0011 00000760 Sep, 18 - 16:32:07 | --Insertion Sort: Enabled
000040| 0011 00000760 Sep, 18 - 16:32:07 | --Shell Sort: Enabled
000041| 0011 00000760 Sep, 18 - 16:32:07 | --Merge Sort: Enabled
000042| 0011 00000760 Sep, 18 - 16:32:07 | --Heap Sort: Enabled
000043| 0011 00000760 Sep, 18 - 16:32:07 | --Quick Sort: Enabled
000044| 0011 00000760 Sep, 18 - 16:32:07 | --CArray Quick Sort: Enabled
000045| 0011 00000760 Sep, 18 - 16:32:07 | Sorting Array Size: 100,000
000046| 0010 00000760 Sep, 18 - 16:32:07 | -Prime Test : Enabled
000047| 0011 00000760 Sep, 18 - 16:32:07 | --Thread Priority: THREAD_PRIORITY_NORMAL
000048| 0011 00000760 Sep, 18 - 16:32:07 | --Iterations: 100,000
000049| 0010 00000760 Sep, 18 - 16:32:07 | -Fast Fourier Transforms : Enabled
000050| 0011 00000760 Sep, 18 - 16:32:07 | --Thread Priority: THREAD_PRIORITY_NORMAL
000051| 0010 00000760 Sep, 18 - 16:32:07 | -Chipset : Enabled
000052| 0011 00000760 Sep, 18 - 16:32:07 | --Thread Priority: THREAD_PRIORITY_NORMAL
000053| 0010 00000760 Sep, 18 - 16:32:07 | -L1 Cache : Enabled
000054| 0011 00000760 Sep, 18 - 16:32:07 | --Thread Priority: THREAD_PRIORITY_NORMAL
000055| 0010 00000760 Sep, 18 - 16:32:07 | -L2 Cache : Enabled
000056| 0011 00000760 Sep, 18 - 16:32:07 | --Thread Priority: THREAD_PRIORITY_NORMAL
000057| 0010 00000760 Sep, 18 - 16:32:07 | -Memory : Enabled
000058| 0011 00000760 Sep, 18 - 16:32:07 | --Thread Priority: THREAD_PRIORITY_NORMAL
000059| 0010 00000760 Sep, 18 - 16:32:07 | -HD : Enabled
000060| 0011 00000760 Sep, 18 - 16:32:07 | --Thread Priority: THREAD_PRIORITY_NORMAL
000061| 0010 00000760 Sep, 18 - 16:32:07 | -MMX : Enabled
000062| 0011 00000760 Sep, 18 - 16:32:07 | --Thread Priority: THREAD_PRIORITY_NORMAL
000063| 0010 00000760 Sep, 18 - 16:32:07 | -SSE : Enabled
000064| 0011 00000760 Sep, 18 - 16:32:07 | --Thread Priority: THREAD_PRIORITY_NORMAL
000065| 0010 00000760 Sep, 18 - 16:32:07 | -SSE2/SSE3 : Enabled
000066| 0011 00000760 Sep, 18 - 16:32:07 | --Thread Priority: THREAD_PRIORITY_NORMAL
000067| 0010 00000760 Sep, 18 - 16:32:07 | -3DNow! : Enabled
000068| 0011 00000760 Sep, 18 - 16:32:07 | --Thread Priority: THREAD_PRIORITY_NORMAL
000069| 1024 000004c8 Sep, 18 - 16:32:07 | Starting Complex Matrix Module on CPU 0
000073| 1032 000001c4 Sep, 18 - 16:32:07 | Starting Chipset Module on CPU 0
000074| 1028 00000824 Sep, 18 - 16:32:07 | Starting Sorting Algorithms Module on CPU 0
000072| 1052 000006f8 Sep, 18 - 16:32:07 | Starting Fast Fourier Transforms Module on CPU 0
000076| 1036 00000178 Sep, 18 - 16:32:07 | Starting L2 Cache Module on CPU 0
000070| 1026 00000888 Sep, 18 - 16:32:07 | Starting Calculating Pi Module on CPU 0
000077| 1038 00000d00 Sep, 18 - 16:32:07 | Starting Memory Mdoule on CPU 0
000078| 1040 00000420 Sep, 18 - 16:32:07 | Starting HD Module on CPU 0
000079| 1042 00000da8 Sep, 18 - 16:32:07 | Starting MMX Module on CPU 0
000071| 1030 000006e8 Sep, 18 - 16:32:07 | Starting Prime Test Module on CPU 0
000080| 1044 00000db4 Sep, 18 - 16:32:07 | Starting SSE Module on CPU 0
000082| 1046 00000dac Sep, 18 - 16:32:07 | Starting SSE2/SSE3 Module on CPU 0
000081| 1048 00000da4 Sep, 18 - 16:32:07 | Starting 3DNow Module on CPU 0
000088| 1044 000008b8 Sep, 18 - 16:32:08 | Starting SSE Module on CPU 1
000089| 1046 000009ac Sep, 18 - 16:32:08 | Starting SSE2/SSE3 Module on CPU 1
000087| 1040 000006cc Sep, 18 - 16:32:08 | Starting HD Module on CPU 1
000075| 1034 00000228 Sep, 18 - 16:32:07 | Starting L1 Cache Module on CPU 0
000086| 1036 000007e8 Sep, 18 - 16:32:08 | Starting L2 Cache Module on CPU 1
000085| 1052 00000684 Sep, 18 - 16:32:08 | Starting Fast Fourier Transforms Module on CPU 1
000090| 1032 00000f7c Sep, 18 - 16:32:08 | Starting Chipset Module on CPU 1
000084| 1030 00000224 Sep, 18 - 16:32:07 | Starting Prime Test Module on CPU 1
000092| 1026 00000220 Sep, 18 - 16:32:08 | Starting Calculating Pi Module on CPU 1
000091| 1024 0000021c Sep, 18 - 16:32:08 | Starting Complex Matrix Module on CPU 1
000083| 1028 00000500 Sep, 18 - 16:32:07 | Starting Sorting Algorithms Module on CPU 1
000093| 1034 00000ee0 Sep, 18 - 16:32:08 | Starting L1 Cache Module on CPU 1
000094| 1038 0000064c Sep, 18 - 16:32:08 | Starting Memory Mdoule on CPU 1
000096| 1048 000009cc Sep, 18 - 16:32:08 | Starting 3DNow Module on CPU 1
000095| 1042 000005b0 Sep, 18 - 16:32:08 | Starting MMX Module on CPU 1
000097| 9999 0000021c Sep, 18 - 16:35:19 | Error:CPU 1: Checksums do not match; Matrix1 = -28115498078.886913, Matrix2 = -28115503932.883739
000098| 0000 0000021c Sep, 18 - 16:35:20 | Minidump file saved at C:\Program Files\Hot CPU Tester Pro 4\\HCTSep18-163520.dmp
000099| 1043 00000da8 Sep, 18 - 16:38:46 | Ending MMX Module on CPU 0
000100| 1037 00000178 Sep, 18 - 16:38:46 | Ending L2 Cache Module on CPU 0
000105| 1039 00000d00 Sep, 18 - 16:38:46 | Ending Memory Module on CPU 0
000103| 1031 00000dac Sep, 18 - 16:38:46 | Ending Prime Test Module on CPU 0
000104| 1049 00000da4 Sep, 18 - 16:38:46 | Ending 3DNow Module on CPU 0
000102| 1045 00000db4 Sep, 18 - 16:38:46 | Ending SSE Module on CPU 0
000101| 1035 00000228 Sep, 18 - 16:38:46 | Ending L1 Cache Module on CPU 0
000106| 1053 000006f8 Sep, 18 - 16:38:46 | Ending Fast Fourier Transforms Module on CPU 0
000107| 1031 000006e8 Sep, 18 - 16:38:46 | Ending Prime Test Module on CPU 0
000108| 1029 00000824 Sep, 18 - 16:38:46 | Ending Sorting Algorithms Module on CPU 0
000109| 1041 00000420 Sep, 18 - 16:38:46 | Ending HD Module on CPU 0
000110| 1043 000005b0 Sep, 18 - 16:38:46 | Ending MMX Module on CPU 1
000114| 1033 000001c4 Sep, 18 - 16:38:46 | Ending Chipiset Module on CPU 0
000111| 1045 000008b8 Sep, 18 - 16:38:46 | Ending SSE Module on CPU 1
000118| 1035 00000ee0 Sep, 18 - 16:38:46 | Ending L1 Cache Module on CPU 1
000115| 1037 000007e8 Sep, 18 - 16:38:46 | Ending L2 Cache Module on CPU 1
000112| 1031 00000224 Sep, 18 - 16:38:46 | Ending Prime Test Module on CPU 1
000113| 1029 00000500 Sep, 18 - 16:38:46 | Ending Sorting Algorithms Module on CPU 1
000117| 1041 000006cc Sep, 18 - 16:38:46 | Ending HD Module on CPU 1
000116| 1031 000009ac Sep, 18 - 16:38:46 | Ending Prime Test Module on CPU 1
000119| 1049 000009cc Sep, 18 - 16:38:46 | Ending 3DNow Module on CPU 1
000122| 1027 00000888 Sep, 18 - 16:38:47 | Ending Calculating Pi Module
000120| 1053 00000684 Sep, 18 - 16:38:47 | Ending Fast Fourier Transforms Module on CPU 1
000121| 1039 0000064c Sep, 18 - 16:38:47 | Ending Memory Module on CPU 1
000123| 1033 00000f7c Sep, 18 - 16:38:47 | Ending Chipiset Module on CPU 1
000124| 1027 00000220 Sep, 18 - 16:38:47 | Ending Calculating Pi Module
000125| 1111 00000760 Sep, 18 - 16:39:19 | Diagnostic has started
000126| 1112 00000760 Sep, 18 - 16:39:19 | Test Duration: 06:00:00
000127| 1113 00000760 Sep, 18 - 16:39:19 | Diagnostic Method: Sequential
000128| 1114 00000760 Sep, 18 - 16:39:19 | Error Handling: Ignore and Continue
000129| 1115 00000760 Sep, 18 - 16:39:19 | Hyper-Threading: Disabled
000130| 0010 00000760 Sep, 18 - 16:39:19 | -Complex Matrix : Disabled
000131| 0011 00000760 Sep, 18 - 16:39:19 | --Thread Priority: THREAD_PRIORITY_NORMAL
000132| 0011 00000760 Sep, 18 - 16:39:19 | --Matrix Size: 3,000x3,000
000133| 0011 00000760 Sep, 18 - 16:39:19 | --Matrix Data Type: Double
000134| 0010 00000760 Sep, 18 - 16:39:19 | -Calculating Pi : Enabled
000135| 0011 00000760 Sep, 18 - 16:39:19 | --Thread Priority: THREAD_PRIORITY_NORMAL
000136| 0011 00000760 Sep, 18 - 16:39:19 | --Pi Iterations: 10,000
000137| 0010 00000760 Sep, 18 - 16:39:19 | -Sorting Algorithms : Enabled
000138| 0011 00000760 Sep, 18 - 16:39:19 | --Thread Priority: THREAD_PRIORITY_NORMAL
000139| 0011 00000760 Sep, 18 - 16:39:19 | --Insertion Sort: Enabled
000140| 0011 00000760 Sep, 18 - 16:39:19 | --Shell Sort: Enabled
000141| 0011 00000760 Sep, 18 - 16:39:19 | --Merge Sort: Enabled
000142| 0011 00000760 Sep, 18 - 16:39:19 | --Heap Sort: Enabled
000143| 0011 00000760 Sep, 18 - 16:39:19 | --Quick Sort: Enabled
000144| 0011 00000760 Sep, 18 - 16:39:19 | --CArray Quick Sort: Enabled
000145| 0011 00000760 Sep, 18 - 16:39:19 | Sorting Array Size: 100,000
000146| 0010 00000760 Sep, 18 - 16:39:19 | -Prime Test : Enabled
000147| 0011 00000760 Sep, 18 - 16:39:19 | --Thread Priority: THREAD_PRIORITY_NORMAL
000148| 0011 00000760 Sep, 18 - 16:39:19 | --Iterations: 100,000
000149| 0010 00000760 Sep, 18 - 16:39:19 | -Fast Fourier Transforms : Enabled
000150| 0011 00000760 Sep, 18 - 16:39:19 | --Thread Priority: THREAD_PRIORITY_NORMAL
000151| 0010 00000760 Sep, 18 - 16:39:19 | -Chipset : Enabled
000152| 0011 00000760 Sep, 18 - 16:39:19 | --Thread Priority: THREAD_PRIORITY_NORMAL
000153| 0010 00000760 Sep, 18 - 16:39:19 | -L1 Cache : Enabled
000154| 0011 00000760 Sep, 18 - 16:39:19 | --Thread Priority: THREAD_PRIORITY_NORMAL
000155| 0010 00000760 Sep, 18 - 16:39:19 | -L2 Cache : Enabled
000156| 0011 00000760 Sep, 18 - 16:39:19 | --Thread Priority: THREAD_PRIORITY_NORMAL
000157| 0010 00000760 Sep, 18 - 16:39:19 | -Memory : Enabled
000158| 0011 00000760 Sep, 18 - 16:39:19 | --Thread Priority: THREAD_PRIORITY_NORMAL
000159| 0010 00000760 Sep, 18 - 16:39:19 | -HD : Enabled
000160| 0011 00000760 Sep, 18 - 16:39:19 | --Thread Priority: THREAD_PRIORITY_NORMAL
000161| 0010 00000760 Sep, 18 - 16:39:19 | -MMX : Enabled
000162| 0011 00000760 Sep, 18 - 16:39:19 | --Thread Priority: THREAD_PRIORITY_NORMAL
000163| 0010 00000760 Sep, 18 - 16:39:19 | -SSE : Enabled
000164| 0011 00000760 Sep, 18 - 16:39:19 | --Thread Priority: THREAD_PRIORITY_NORMAL
000165| 0010 00000760 Sep, 18 - 16:39:19 | -SSE2/SSE3 : Enabled
000166| 0011 00000760 Sep, 18 - 16:39:19 | --Thread Priority: THREAD_PRIORITY_NORMAL
000167| 0010 00000760 Sep, 18 - 16:39:19 | -3DNow! : Enabled
000168| 0011 00000760 Sep, 18 - 16:39:19 | --Thread Priority: THREAD_PRIORITY_NORMAL
000170| 1030 00000a1c Sep, 18 - 16:39:19 | Starting Prime Test Module on CPU 0
000169| 1026 00000a14 Sep, 18 - 16:39:19 | Starting Calculating Pi Module on CPU 0
000173| 1034 0000033c Sep, 18 - 16:39:19 | Starting L1 Cache Module on CPU 0
000172| 1028 00000a18 Sep, 18 - 16:39:19 | Starting Sorting Algorithms Module on CPU 0
000174| 1036 00000a44 Sep, 18 - 16:39:19 | Starting L2 Cache Module on CPU 0
000171| 1032 00000a3c Sep, 18 - 16:39:19 | Starting Chipset Module on CPU 0
000175| 1052 00000a24 Sep, 18 - 16:39:19 | Starting Fast Fourier Transforms Module on CPU 0
000176| 1038 00000a48 Sep, 18 - 16:39:19 | Starting Memory Mdoule on CPU 0
000177| 1040 00000a54 Sep, 18 - 16:39:19 | Starting HD Module on CPU 0
000179| 1044 00000a64 Sep, 18 - 16:39:19 | Starting SSE Module on CPU 0
000180| 1046 00000a68 Sep, 18 - 16:39:19 | Starting SSE2/SSE3 Module on CPU 0
000181| 1048 00000a6c Sep, 18 - 16:39:19 | Starting 3DNow Module on CPU 0
000178| 1042 00000a58 Sep, 18 - 16:39:19 | Starting MMX Module on CPU 0
000185| 1034 00000a88 Sep, 18 - 16:39:19 | Starting L1 Cache Module on CPU 1
000183| 1030 00000a7c Sep, 18 - 16:39:19 | Starting Prime Test Module on CPU 1
000182| 1028 00000a78 Sep, 18 - 16:39:19 | Starting Sorting Algorithms Module on CPU 1
000186| 1026 00000a74 Sep, 18 - 16:39:19 | Starting Calculating Pi Module on CPU 1
000187| 1032 00000a84 Sep, 18 - 16:39:19 | Starting Chipset Module on CPU 1
000188| 1036 00000a8c Sep, 18 - 16:39:19 | Starting L2 Cache Module on CPU 1
000189| 1038 00000a90 Sep, 18 - 16:39:19 | Starting Memory Mdoule on CPU 1
000184| 1052 00000a80 Sep, 18 - 16:39:19 | Starting Fast Fourier Transforms Module on CPU 1
000191| 1046 000003d0 Sep, 18 - 16:39:19 | Starting SSE2/SSE3 Module on CPU 1
000194| 1048 00000aac Sep, 18 - 16:39:19 | Starting 3DNow Module on CPU 1
000193| 1044 00000a9c Sep, 18 - 16:39:19 | Starting SSE Module on CPU 1
000192| 1040 00000a94 Sep, 18 - 16:39:19 | Starting HD Module on CPU 1
000190| 1042 00000a98 Sep, 18 - 16:39:19 | Starting MMX Module on CPU 1
000195| 9999 00000a18 Sep, 18 - 16:39:48 | Error:CPU 0: MFC QuickSort: Checksums do not match; a[370844] = 30370, a[370844] = 30369
000196| 0000 00000a18 Sep, 18 - 16:39:48 | Minidump file saved at C:\Program Files\Hot CPU Tester Pro 4\\HCTSep18-163948.dmp
000197| 9999 00000a84 Sep, 18 - 16:43:52 | Error:CPU 1: Memory cells do not match; cMem1[1185799] = 17, cMem2[1185799] = 16
000198| 0000 00000a84 Sep, 18 - 16:43:52 | Minidump file saved at C:\Program Files\Hot CPU Tester Pro 4\\HCTSep18-164352.dmp
000199| 9999 00000a3c Sep, 18 - 16:43:58 | Error:CPU 0: Memory cells do not match; cMem1[3699909] = 37, cMem2[3699909] = 36
000200| 0000 00000a3c Sep, 18 - 16:43:58 | Minidump file saved at C:\Program Files\Hot CPU Tester Pro 4\\HCTSep18-164358.dmp
000201| 9999 00000a90 Sep, 18 - 16:49:43 | Running...
000202| 0000 00000a90 Sep, 18 - 16:49:44 | Minidump file saved at C:\Program Files\Hot CPU Tester Pro 4\\HCTSep18-164943.dmp
000203| 9999 00000a78 Sep, 18 - 17:12:08 | Error:CPU 1: MFC QuickSort: Checksums do not match; a[57396] = 4712, a[57396] = 4711
000204| 0000 00000a78 Sep, 18 - 17:12:08 | Minidump file saved at C:\Program Files\Hot CPU Tester Pro 4\\HCTSep18-171208.dmp
Sponsored Links
Could be ram. Have you tried running memtest? Also, you didn't list your specs. If it's an nforce mobo and you're using the onboard nic with nvidia's active armor it could be corrupting your downloads. Some versions of active armor didn't work well.
Reply to hawkeye22
ran memtest 86+ v1.7 for 4 passes and it checked out ok, no errors. running off-board NIC.
Specs are:
AMD Athlon 64 X2 3800+
Jetway 939GT4-SLI-G mobo (NForce 4)
2 x 512mb Crucial Ballistix DDR 400 (latency - 2-2-2-6 unbuffered) running in Dual-Channel mode
2 x 80gb seagate barracudas SATA2 3.0gb/s non-raid
WD 160gb SATA 1.5gb/s
WD 120gb ide
Drives arent the problem though
eVGA GeForce 7600 GT PCI-E 16x(also not the problem)
Nothing is overclocked memory timings are set to 2-2-2-6 in bios.
Reply to checker6
Forgot to note the log shows but i will re-iterate i am running Windows XP Professional SP2 fully patched
Reply to checker6
Is your OS from a torrent?
Reply to rsetter1
No, it is a legit CD i have been using for years on different machines with a volume license key from my employer.
Reply to checker6
There are 587 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
