Problems Adjusting CPU Voltage
I'm using a Biostar TForce4 Mobo with a amd 3500+ Orleans. I recently Overclocked my CPU from 2.2 to 2.6, anything over that runs unstable without changing the CPU voltage. I notice a difference in performance. and my cpu runs 35-42C. After OC'in temperatures didn't change.
I've read numerous accounts on Overclocking the 3500+ and most say that it runs hot a 2.6ghz or higher, and that it cannot run passed 2.4 w/o adjusting the CPU voltage.
Since my CPU is still relatively cool, I wanted to up the voltage so it can run passed 2.6. But on my BIOS, there isn't an option or i can't access an option to adjust CPU voltage.
Is there another way to adjust the CPU voltage values?
1 answer Last reply
More about problems adjusting voltage
  1. Under your mobo's manual and/or website you can acquire the manual. All possible settings are listed there. Or you can use the best thing, google. Search Biostar TForce4 cpu voltage
CPUs Biostar Overclocking
