I have got an e6300 with the stock heatsink and fan. I did get the thermal paste (arctic silver 5) a few months ago. Used it and the temps were around 35 etc. However, I just noticed that the temps are back up running around 60 normal and mid 70 under load (using TAT). The temps are with one side of the case open btw.
1. Should I take off the heatsink and re-apply the paste?
2. Should I get an after market heatsink and fan? (if so then which one?)
3. Should I go with water cooling? (never done it before but it sure sounds tempting)
I want to stay under $100.00 for whatever solution you guys provide. Ideally I would like to overclock this cpu to atleast 75% of its potential but need to keep the temps low obviously. Right now, I am not ocing at all.
You guys have always helped out so I def appreciate it.
Below is the list of my components.
E6300
Antec PERFORMANCE TX TX1050B Black Steel ATX Mid Tower Computer Case
500W Power Supply
ATI X1950xt
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
E6300
500W Power Supply
ATI X1950xt
