Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > evga 8800 gts card power source, the 16X connector?
Forum Graphic & Displays : Graphics Cards - evga 8800 gts card power source, the 16X connector?
I new to building up a PC..Is the power for 8800 gts come from the 16X pci-e connector itself? When I turned the system power button on, case speaker made an alarm sound....no video came up...there are connectors on the IP35 pro MB labelled PCI-e power and AUX pci power
Do I need to connect power to those 2 MB connectors for 8800 gts to work?
Thanks in advance ,
Vince
Sponsored Links
Theres a power connector for the GTS? ...You have to plug something into the card, I dont know what, it should have came with your gfx card. It plugs on the end of the card.
Reply to ShortRef
Power for the GTS comes from the pcie slot and also a 6 pin pcie connection from the psu, if your psu does not have a 6 pin connector you would use the "Y" adaptor that is included with the card.
The connections on your motherboard are there to provide power to it not to the card.
Reply to Delluser1
- 0 +
If your PSU doesnt have a PCI-E 6pin connector, you can use a molex to PCI-E connector. It does take 2 molex's though.
------------------------------ Na na na na na na na na HATMAN!
Reply to Hatman
Thank guys for the help so far...But I just want to be clear...the 8800 gts card has only 1 connector...the big 16x pci-e one
look at this pic of the ip35 pro MB
http://s201.photobucket.com/albums [...] 800gts.jpg
which of those 2 connectors do i need plug from the power supply?...
thanks Vince
Reply to vince32837
- 0 +
thanks Vince
look at this picture and follow the red line:
http://www.newegg.com/Product/Show [...] Video+Card
------------------------------ P35-DS3L Rev 2 bios F9C l E8400 @ 3.6Ghz @ 1.232v l OCZ Vendetta 2 /LGA775 Bolt-Thru l 4GB G.Skill 8800PI@1000mhz 4:5 @ 1.87v l WD3200AAKS 320GB l Evga 8800GTS 512 l X-Fi Xtreme Music l Corsair HX520 l Antec Sonata III 500 l Vista32 SP2 l Win7 X64 7600
Reply to kpo6969
PCIe 1 is an expansion slot not a power connection, the 4 pin Molex connection is there to provide extra power for the second PCIe slot if you intend to go sli.
Put the card in the slot, add the 6 pin connection from the psu to the card and enjoy.
Reply to Delluser1
thanks guys that was it!!!!!!!!!!!!!!!!!!....I'm loading XP pro now
building a PC from the case up...pretty nice feeling..........
thanks Vince
Reply to vince32837
There are 747 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
