Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > ATI 2950XT power requirements?
Forum Graphics & Displays : Graphics Cards ATI 2950XT power requirements?
Anyone wanna take a shot at guessing comparing requirements of 2900xt and other mid range cards? considering it is using 55nm process, i would say 400W PSU with 18 amps on 12V
Reply to devilray26
Not a chance
30a
------------------------------ EP45-UD3P Rev 1.1 bios F11c / E8400 @ 3.71Ghz @ 1.248v / OCZ Vendetta 2 /LGA775 Bolt-Thru / 4GB G.Skill 8800PI@1100mhz 3:4 @ 1.88v / Saphire 5700 Vapor-X l X-Fi Xtreme Music / Corsair HX520 / Antec Sonata III / Win7 x64 b. 7600.20796
Reply to kpo6969
No way in hell.
At best I would say it will consume no less than 140w under full load by itself. That means 11.67 amps just for the 2950XT if it were to be clocked at the same speed as the 2900XT.
Also, 55nm process is incorrect. It will be based on the 65nm process and will likely be clocked higher than the 2900XT so I'm sure that my 140w estimate is on the low end.
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
jaguarskx wrote :
No way in hell.
Almost everyone is saying that it is 55nm...but I have saw a small percentage of sites report 65nm. Which is it? Have any links?
Thanks...well, I guess it doesn't matter what process it is...if it draws less power, runs cooler, and is just as fast or more, that's great, whatever!
Reply to General_Disturbance
- 0 +
I believe it's 55 nm. They were originally planning to do 65nm but switched to 55nm from all the sources I've read. While nvidia will stick with 65nm...They are both being produced at TSMC. TSMC Also has a 55nm production capabilities..so it could be true. But it has been a rumor. Overall I think it will come to be though....But time will tell.
Reply to Kamrooz
Well 2950-series has two different models, namely Gladiator and revival.
Just rumours again but check this table
http://www.fudzilla.com/index.php? [...] &Itemid=34
Gladiator (RV670 XT) has 135W TDP
Revival (RV670 Pro) has 105W TDP
2950X2X (Dual card 2xRV670 chips) about 200W
2950X2X:
and some other related links (RV670).
Sorry about so many fudzilla(a rumour mill) links but this is all that I know.
Message edited by PhantomBlot on 10-12-2007 at 10:06:00 AM
Reply to PhantomBlot
There are 2070 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Bad PCI-E Slot or Bad Graphics Card?
By smorizio, 40 minutes ago:
check that you have all the power cables plugged into your video card..some have one some...
Best offers
Top experts
