Hey guys
I recently bought new components to build a PC of the following spec.
Intel Core 2 Duo E6750 @ 2.66ghz
ASUS P5K-E
2GB Crucial Ballistix PC2-8500 1066mhz ram
BFG GeForce 8800GTS 640MB
OCZ GameXstream 700W PSU
Samsung SH-S203B 20x DVD-RW
2x 250GB Seagate ST3250410AS SATA II HDD
ThermalTake Tsunami Case
Now my problem is, when i attach the 3 case fans to the PSU everything loads up fine and i get the BIOS. However, if i plug in the HDD's, the PSU blips on then goes off immeadiately and everything stops. I tried unplugging some fans and putting hte HDD's in and get the same problem. Can anyoen shed some light as to WHY?
ALso, should there only be one lead from the PSU into the G-Card? Or should there be two, because i can't find a second slot to plug stuff in.
Thanks
ASUS P5K-E
Thanks
