News
Wireless carriers face slowdown of subscriber growth
Published on February 13, 2007
As the global wireless industry convenes today for its biggest event of the year, the 3GSM World Congress 2007 in Barcelona, Spain, carriers participating in the event face a major challenge: how to maintain revenue growth amid a dramatic slowdown in new handset subscribers. Read more
Alienware announces desktop PC with Intel's latest quad-core processor
Published on January 11, 2007
Alienware said it "will" launch Intel's second quad-core desktop processor, the 2.4 GHz Core 2 Quad Q6600, on its Area-51 7500 desktop system. Read more
Sun Microsystems To Cut Up To 2,500 Jobs After U.S. Slowdown Cuts Sales
Published on May 06, 2008
Sun Microsystems is to cut between 1,500 and 2,500 jobs after an unexpected $34 million three months loss. Read more
Latest Reviews & Articles
System Builder Marathon: Performance & Value
Published on October 31, 2008
Three dramatically different builds face off in show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
System Builder Marathon: $500 Gaming PC
Published on October 30, 2008
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
Tom's SBM: The $1,500 Mainstream PC
Published on October 29, 2008
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
System Builder Marathon: The $4,500 Super PC
Published on October 28, 2008
This month's System Builder Marathon spreads the system prices out even further to $4,500, $1,500, and $500. Is today’s $4,500 system really worth three times as much as an upper-mainstream performance machine? Read more
  Tom's Hardware Forums » CPU & Components » CPUs » Q6600 Constant Slowdown - Help
Word :   Username :
Bottom
Author
 Thread : Q6600 Constant Slowdown - Help
Profile: stranger
More Information
I recently installed a Q6600 into my PC and I've noticed it's been alot slower then my previous 2.40GHz Core 2 Duo, I'm not sure if it's a hardware or a software issue here but listed below is what my setup is at the moment:
Q6600
Asus P5N32-Sli (650i chipset)
4GB RAM
Nvidia 7900GS
900w Modular Power Supply (Can't remember the name off the top of my head)
2x 250GB Hard drives
I did have an Sli installed before this but taken out 1 card to see if it helped, so I'll put that back in after I've solved this constant slowdown but any help would be excellent as I'm at a dead-end with this.
Related Product
Profile: enthusiast
More Information
What's your temps and did you reinstall your OS? Should be the same speed as your previos E6600 on most apps and faster on others.
E6420 @ 2.66 w/ Zerotherm CF900
Gigabyte DS3 rev. 1.3 @ 1333
4GB Patriot DDR2800 @ 667
Gigabyte 8800GT w/ VF830 700/1715/1840
Profile: stranger
More Information
I can get the temps for you in a minute but no, I've not installed the OS. Never really thought you'd need too with a CPU.
As for a speed difference compared to the E6600 it's significantly slower then the E6600 at the moment.
Profile: enthusiast
More Information
If your temps are too high you might be throttling. As for the OS reinstall, technically you shouldn't have to but if it's Windows we're talking about you never know. I always reinstall after any major hardware change just to be sure I'm getting full performance. Does your OS recognize all 4 cores in device manager?
Profile: stranger
More Information
It does recognize all 4 Cores in Device Manager, Just browsing w/ Firefox it's sitting on 30 Degrees however I did try to play some music a minute ago and it wouldn't play anything without a huge amount of stuttering. Just did a restart and getting the same results.
Profile: enthusiast
More Information
Well Asus's site regarding your MB is pretty outdated but it looks like most of the recent BIOS updates address cpu support, you might check and see what version your running. When your saying that it stutters during music, open task manager and see what cpu usage is at. Check to see how many processes are running. Your cpu should plow right though most anything you throw at it, but check anyways. Your temps are great so that's out.
Profile: Honorary Poster
More Information
I agree with Scarchunk. Update your BIOS to see if it helps. If I remembered correctly, all 650i chip has quad core support, but you need to update the BIOS.
http://i62.photobucket.com/albums/h82/TXSuperFly03/478x88copy.png
Profile: stranger
More Information
right I can look at updating the motherboard, I've found Asus drivers a pain to update in the past. on my G15 keyboard it was showing the CPU at >50% usage with just WMP (while playing a track) and Firefox.
Message edited by asauka on 09-29-2007 at 06:56:26 PM
More Information
You should try updating the BIOS, before you drop the big bucks. I currently also have Q6600, and it works like a charm.
Don't use ASUS's updating software. Use DOS to update the BIOS. Its safer, more reliable, and faster. Try updating your BIOS to 0703, and see if it works.
As for 50% usage, I'm suspecting its a code error in OS. I'm not sure though, but if you can, and have the will and energy for it, try to reinstall the OS.
Profile: enthusiast
More Information
I've had a few Asus boards and they have an app that I think is called Asus Update. DON'T try and use its update through the internet function as it sucks. Download the BIOS update to your computer and then tell the Asus Update program where to find it locally on your computer. It has always worked fine for me as long as you DO NOT tell it to update from the net. As for 50% usage with media player....somethings wrong. How many other processes do you have running?
Profile: stranger
More Information
Installed the BIOS update and it's working perfectly now. Thank you all for your help, most appreciated.
Google Ads
