Need to update my 4 year old PIV 3.0GHZ, ATI AIW X800XT system with 1GB Corsair PC3200. After reading through the high end article here and over at sharkyextreme I have put together a wish list at newegg with the following:
Asus P5N32-E SLI
Intel E6850 core 2 duo
Crucial ballistix PC2 6400 X 2 for 4GB total (same part# as recommended in high end build article)
EVGA 8800GTX 768-P2-N831-AR
PCP&C 750w pwr supply
I might dable in overclocking a bit but will probably just run it stock at first. I have a Dell 2407 24" monitor that I would really like to run at full resolution and looking forward to playing the new COD 4 coming soon. I am also a MS FSX player as well as BF2-2142, COD UO and COD2. I also run Photoshop CS3 which is why I really want all the RAM i can get even if the 32bit sys wont see it all. it will see most of it.
If I might ask you knowlegable people what your thoughts are on this system and if I should consider some changes? Thank you for any info in advance.
Jeff
Asus P5N32-E SLI
Jeff
