Video Card: (these are the two I am thinking about)
ASUS EAH2600XT D4/HTDI/256M Radeon HD 2600XT 256MB 128-bit GDDR4 PCI Express x16 HDCP Ready CrossFire
or
MSI NX8600GTS-T2D256E-OC GeForce 8600GTS 256MB 128-bit GDDR3 PCI Express x16 HDCP Ready SLI
I would like to buy a fair (about $150) card now to get by and purchase a good card (about $500-$800) in a few months as things develop in this market.
1. Should I run Vista in 32 or 64 Bit? Currently running in 32.
2. Wasn't planning on ability to go SLI or Crossfire. Should I?
3. No one has addressed what ATI's new driver release has made the info. in Tom's Direct10X Shootout outdated. I would like to see the few ATI cards retested to see the results and the OverClocked cards put in a seperate category. Any idea how this release has effected the lineup in my scenerio?
4. What card/cards should I consider at this time?
5. Should I consider not employing Direct10X at this point?
6. Have I made any mistakes in my system configurtion choices?
I apologize if my format is incorrect. I have never posted in a forum before.
I would like to play games on the 42inch in Direct10X at high resolution. ....how high??
since u want to play on a high res on a 42inch your probably gonna need 8800GTXs in SLI... of coruse depening on Res and what Settings you want to run the game but if the Res is 1920 x 1200 or higher and you want to play the game on High/Max settings...i would highly suggest 8800GTX in SLI
2. if your getting 4gigs of ram you need to have a 64bit OS either XP64 or Vista 64.....32bit only would support 3.2gigs of Ram..
3. as for the motherboard if your going SLI you need to look at Nforce680i chipset and i suggest either EVGA or Abit Motherboards (i know for a fact Abits IN9 is 219.00 on newegg)
Vista came with both the 32 and 64 bit version so I can change to 64 if it is beneficial overall and wont cause huge problems with other software and driver compatibility.
My 42inch will support: 1024 x 768, 720p and 1080i I don't have much experience playing games on it to know what will look good and what won't. Let me know.
So what I am gathering so far is that I am going to have to go with SLI or Crossfire to get an acceptable picture quality and frame rates on that monitor? Even if I run it in 1024 x 768? I am not going to be able to get by with a one card system?
I'd say buy as cheap of a PCI-E video card with DX10 as you possibly can. Why? because you'll save more money and thus reach that projected $500-$800 figure you want to spend much faster. If not, I suggest this...
Being that you want high resolution, yes. I do suggest this card in SLI. Reason being is that it has higher clocks than all the other 8800GTX's out there (on par with Ultra), and I personally own so I can speak on its behalf.
According to several sites, which can be foudn here by browsing THG, or a Google Search, that the 7.10 drivers don't have nearly as high of an impact on performance gains in a single GPU setup as it would in Multi-GPU setups. (Crossfire).
The one I suggested, amongst others such as the HD2900 pro, which can be OCed to HD2900XT levels, the 8800GTX and 8800GTX Ultra, HD2900XT, 8800GTS 640MB, and potentially the new 8800GT.
It's hard to say. I say this, "To each his own." It's your PC, run it how you want. If you want eye candy but hampered performance compared to DX9 applications, than I'd stay away from it. Personally, I'd say no. I'd also say this, if you're running high res, and you want eye candy, DO NOT invest in an ATI Product at this point. They have AA issues at the moment.
justinmcg67,
Message edited by kpo6969 on 10-17-2007 at 01:20:19 AM
------------------------------ P35-DS3L Rev 2 bios F9C l E8400 @ 3.6Ghz @ 1.232v l OCZ Vendetta 2 /LGA775 Bolt-Thru l 4GB G.Skill 8800PI@1000mhz 4:5 @ 1.87v l WD3200AAKS 320GB l Evga 8800GTS 512 l X-Fi Xtreme Music l Corsair HX520 l Antec Sonata III 500 l Vista32 SP2 l Win7 X64 7600
Reply to kpo6969
Reply to kpo6969
running a card in SLI mode? doesn't this mean using two cards? I can't do what I want with one?
why does running in 32bit hurt your performance? I thought it supported more RAM and helped performance in games, multitasking and certain applications?
I mean that at the resolution of your 42" monitor, a single 8800GTX will handle most (if not all) games at max settings with ease. Two 8800GTXs in SLI is a waste of money.
why don't you tell us what model and make the 42" is? we should have known that to begin with. i'm betting it's 1366x768. or 1280x720. in either case, as wolf correctly pointed out, that resolution is not "high res". that's tiny. a 8600GTS will likely handle that very nicely in most cases. if you absolutely need to make sure, wait for the 8800GT and get the 256MB version for 199. but yeah, that 42" may be big, but it's not high res.
------------------------------Phenom II X4 940 (3.6GHz @ 1.52vCore) : Arctic Cooling Freezer 64 Pro : 8GB OCZ DDR2-1066 : EVGA GeForce GTX 260 Core 216 (55nm), 701/1501/1175MHz C/S/M: Asus M3A78-EM 780G mATX Mobo : WD 750GB BE HD, SG 7200.11 1.5TB HD : Corsair 650W PSU
Reply to cpburns
OK so I can run a single card in high res to get what I want. What should I buy now to get by till I want to spend the money for a high end card? and will it be able to run 10X and at what res?
no one mentioned why to not run Vista in 64 bit........?
or what the SLI mode comment means.......is this applicable to running one card?
Your plasma is not a true HDTV screen. Yes it is advertised as an HDtv but it just means it can display an HD signal, but not at full resolution.
Your plasma's native (i.e. actual) resolution is 1024x768 so no matter how high you set your pc's resolution thats all you'll actually see, so there's no point in setting it any higher than 1024x768. The bottom line is that just about any DX10 card will scream at that res.
So-called HDTV's like yours support any signal with a resolution higher than 1024x768 (such as HD) by scaling it down to their native resolution so losing detail. Yes its a scam based on misrepresentational advertising, and yes all the manufacturers are doing it.
Actually you would probably get a much more detailed so better (but overall smaller) picture on your 24" monitor. I'm guessing at that size its native res. is 1920x1200. If so it can fully display native HD too (1920x1080).
NIZ great answer and explanation thanks...........yes my 24 is a SUN hi rez CAD monitor that can support more than I have ever thrown at it.
For some reason I like playing on the big screen......I can sit on my couch instead of at my desk which I do all day.......I guess I am not a true gamer!
So all that said what for 1024 x 768 what card should I buy for 10X?
I'd say either of the two cards you listed in your original post (the AMD 2600XT or the NVidia 8600GTS) would suit you nicely until you've saved up enough for your high-end card in the future (if you even need a higher card).
As for Vista 32 vs Vista 64, if I were in your shoes and if I had a couple weeks to rebuild and test, I'd probably try out Vista-64. Look for any incompatibilities and make sure all I want to run, actually does run. If it does, leave 64-bit Vista on there, if not, reformat and reinstall with Vista 32 bit.
-Wolf sends
Edit: Note I'm running XP-64 on my dedicated gaming rig. It runs everything I've asked it to without issue, so I left it on.
Message edited by Wolfshadw on 10-17-2007 at 05:14:11 AM
