Hi, i was wondering if a Q6600 would work on a abit iL9 pro motherboard
http://www.komplett.ie/k/ki.aspx?sku=327806
Here are its specs
Product Description ABIT IL9 Pro - motherboard - ATX - i945P
Product Type Motherboard
Form Factor ATX
Dimensions (WxDxH) 30.5 cm x 24.4 cm
Chipset Type Intel 945P Express / Intel ICH7
Max Bus Speed 1066 MHz
Processor 0 ( 1 ) - LGA775 Socket
Compatible Processors Pentium 4, Celeron D, Pentium D, Core 2 Duo
RAM 0 MB (installed) / 4 GB (max)
Supported RAM Technology DDR II SDRAM
Storage Controller ATA-100, Serial ATA-300
USB Ports Configuration 8 x USB
Storage Ports Configuration 1 x ATA, 4 x SATA
Audio Output Sound card - 7.1 channel surround
Networking Network adapter - Ethernet, Fast Ethernet, Gigabit Ethernet
I've been looking everywhere for an answer and id really appreciate it if someone knew
Thanks
Here are its specs
Form Factor ATX
Thanks
