Tom's Hardware > Forum > Overclocking > General Discussions > Help overclock E6750 and MSI p6n sli
Forum Overclocking : General Discussions - Help overclock E6750 and MSI p6n sli
Ok so I am an overclocking noob. I have been reading a ton about how to overclock and I think that I am getting the basics down, but I cant seem to get the computer to let me go higher than 3.0 ghz. My Ram is patriot extreme 2x1gb 4-4-4-12 timing. I have followed the basics on this thread http://www.tomshardware.com/forum/ [...] clock-650i although it is for a 6600 I used some of these settings to disable things in the bios. Any suggestions would be great.
Sponsored Links
need a few more details. What voltages are you using @ 3.0ghz. It may also be that you need to loosen your memory timings a bit while doing the overclocking.
When you say you can't get past 3.0ghz what do you mean? Do you mean you can't post or get into windows or do you just fail a stability test?
------------------------------ DD Water Box Plus, QX9650 @ 3.9ghz, eVGA 780i, 4GB Corsair XMS2 DDR2 800(2x2gb), WD Raptor 150gb, 500gb Seagate Barracuda, BFG 8800GTX 620/2000 x 2 SLI, Tagan BZ 1300w PSU, Custom 120.2 Water Cooling
Reply to nzxtlexa
Sorry... the voltage for 3.0ghz is set to 1.336 (+.0250). The timings are at 4-4-4-12, should I change them to say 5-5-5-15? and what i mean by cant get past 3.0ghz is the system locks up and right before bios it says that processor is for 333 and resets it back to last good config. hope this helps.
Reply to jbn07
Ok, it maybe that you need to increase your vcore a bit but also some other voltages eg nb core and sb core which will need increasing to help with stability, I'll need to know these as well if possible. Before increasing the voltages do try loosening timings to like you said eg 5 5 5 15 or 5 5 5 18. Also what is your FSB:RAM ratio. This will either be a number like 5:4 (ddr2 800) or it will say "linked" or "unlinked", but it depends on which mobo chipset you are using.
sorry about all the info needed!
Reply to nzxtlexa
Do NOT raise SB voltage. Make sure your PCIe freq is locked at 100MHz as well. You shouldn't need to raise NB voltage just yet. I'm guessing you had your RAM:FSB set too high. RAM won't post much past rated speed.
Reply to Thanatos421
Ok here are the settings and voltages:
DOT Disabled, EIST Disabled, CPU Spread Spectrum Disabled, PCIE Spread Disabled,Cpu spread disabled,sata spread disabled, bit suppot disabled,set limit cpu id disabled, C1E disabled, HPET disabled, COmmand per clock 1T (memory), FSB 1500, RAM 800, PCIE 100, DRAM 4-4-4-12 rest auto, cpu volt .0250 (core 1.336) memory volt 2.20, NB 1.25 default, SB 1.50 default, FSV VTT Volt 0%.
Hope this is enough info. TIA
Reply to jbn07
Ok thanks. What to do:
1. Loosen timings of ram and try to boot
2. Then start adding bits to your vcore while trying to boot after each, keeping a careful eye on temps
3. It may be that your NB voltage also needs a small increase to say 1.3 but watch temps.
4. If you pass 400mhz then you MAY need to add 0.5 to SB.
This is just to get you past the 3.0ghz mark but after that you will need to increase all of these more to get a higher frequency.
Try these in order. I reckon its a voltage issue so try adding to that for stability, but be very careful with temps.
Reply to nzxtlexa
Well I must be a crazy noob because I cant get above 3.04ghz. First of all what should I loosen the timings to? What about the command per clock setting I have 1T 2T and Auto to work with?
Reply to jbn07
Set command rate to 2T and your RAM timings to 5-5-5-15. You want your RAM to be as flexible as it can be while you dial in your CPU speed.
I already have those settings right it must be a voltage thing. I set the vcore to 1.4 and the NB to 1.3 and when i went over 1524 fsb it will freeze during windows startup. Could it be the SB? If so isn't that where you can start screwing things up?
Reply to jbn07
Well if your aiming at booting at 3.0ghz to begin with, surely you need your fsb to be @ 1500 as 1500 / 4 = 375 and 375 x 8 = 3000 (or 3ghz). Or at least thats what it should be at if you are using a 8x multiplier.
What cooling are you using at the moment. If you have any quite decent form of after market HSF, then I wouldn't worry about increasing the vcore some more and seeing if you can boot with this. Don't forget you can more or less run a PC 24/7 with the vcore at about 1.5, just make sure you have good cooling. try referring to some of the overclocking guide at the top of the forum to see the other voltages that may need increasing. I'm not saying that you should set the vcore to 1.5 immediately and see what happens, but simply work you way up the 1.3's a little whilst monitoring temps.
Reply to nzxtlexa
Vcore at 1.4 is REALLY high for a 6750 at 3.0GHz. Most likely, you need to raise the NB a hair. I clocked my 6750 to 3.0 on stock voltage. I'm just a hair over 1.4v at 3.6!
Make sure once again that your RAM divider is set 1:1 and your RAM is getting proper voltage. That should completely remove RAM as the culprit unless you have a bad stick. You can leave the vcore at 1.4 for the time being, but once you get it to post, lower it back to 1.35 at least and see if it still boots. It should quite honestly.
Up the NB to 1.4 as well. It won't hurt it. But I wouldn't suggest going over 1.6 on the NB as it tends to get hot quickly.
Try that once and let us know :)
Sorry for the confusion I can get to 3.0 with a 1.336 vcore, i just left it there after trying to get it higher. BTW I have a Cooler Master Hyper Tx2 cooler and with the vcore at what it is right now it is sitting at 43 under prime 95 load. Im not sure if my mobo has a 1:1 memory setting or maybe it is disguised as something else?
Reply to jbn07
That seems really really cool for full load on air. Did you calibrate your thermal monitoring before you started?
Well im using core temp... how do i calibrate?
Reply to jbn07
CPU section, CompuTronix sticky post.
Thanks ill check it out... this is why i have been reluctant to do anything crazy. BTW with the above suggestion i am up to 3.15ghz
Reply to jbn07
Ok I calibrated my temps and I am getting 60c at prime small fft test oc at 3016mhz. How much higher can I go?
Reply to jbn07
That depends on how long you want to use this particular system. Also, I'm not familiar with your HSF so I can't be sure how fast heat will get out of control.
In my case, im at 3.6GHz with 1.425 vcore at 67c peak hottest core 24 hours under Prime. That is getting a little warm honestly. If I were concerned with keeping this system more than 1-2 years, I would back it off a notch. If I wanted to make sure I wasn't damaging something over time, I would probably keep my peak load temperature on my hottest core around 62c max. Shutdown on the Core2 line is 72c on the Tcase sensor I think. Comp's guide has proper values I believe.
Try to hit 3.4GHz next without touching the vcore. You still may even be able to lower it a touch. Lowering voltage will drop your temperatures a good bit. See if you can post 3.4GHz with 1.35 vcore. If it passes POST, then stress it.
This is where it will get tedious, because you really need to keep an eye on your temperatures for a good while, or find a way to log the temperatures to a .txt file. I think SpeedFan has that ability, I'm not sure, I just glanced back and forth at my PC for 8 hours one Saturday :p
If the temperatures look good, then let it run overnight. If it doesn't error, then try lowering the voltage again, OR if the temperatures look GREAT ~60c (remember, you lowered the vcore from 1.4 to 1.35 so that will eliminate a good deal of heat) then if you want to, try 3.6. However, at 3.6, you will probably need 1.4ish vcore and that much voltage and that extra 200MHz will generate a good deal of heat. With a Thermalright Ultra 120 Xtreme and Scythe S-Flex 83CFM fan it hits 67c at peak. If we assume that your cooler is slightly less efficient (TRUE is generally considered one of the best) then you would really want to keep a close eye on your core temps. If you see 68c even for a second, kill it, and clock it back to 3.4. That will most likely be your sweet spot. I don't know honestly, it's all trial and error, but that's what makes it fun :)
Ok well I am stress testing at 3.2ghz with stock vcore. It seems like the NB was the problem I bumped it up to 1.4 and it seems to give stability. Prime has been running for about 10 minutes with a 62c high. should i let it go all night? Another question is the the memory says 778 i think, how can i bring this back up.
Reply to jbn07
Well it froze the previous posts settings so I dropped the oc down to 3.1 and the NB down to 1.35 prime has been running for a while and it has leveled off at 63. Should I stop there?
Reply to jbn07
OK glad you got things going. Yes to be honest for the longevity of the system, you don't want the run the system any hotter than that, so I would keep it at 3.1 an maybe invest in a better hsf for the future. Still not a bad overclock.
Reply to nzxtlexa
OK Ill keep it there and get another HSF. You gotta admit though that this current HSF wast bad for a dollar at newegg with the rebate.
Reply to jbn07
Damn I wish some places in the UK offered rebates!
Reply to nzxtlexa
There are 1157 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
