Hello peoples!
Just bought myself a good pc from ebuyer. Going all smoothly untill evrything is plugged in ready to go and the worst thing happened! No signal was being recieved by my montier?
Right i uplugged everything and started from scratch and started again same problem.
In more precise words i bought the following :
Intel Core 2 Duo E6550 2.33GHz 1333FSB Socket 775 4MB Cache Retail Boxed Processor
OCZ 2GB Kit (2x1GB) DDR2 800MHz/PC2-6400 CL 4-4-4-15 PLATINUM XTC with LIFETIME WARRANTY
1 x ABIT IB9 iP965 Socket 775 DDR2 PCI-E 7.1 channel audio ATX
1 x Seagate ST3320620AS 320GB Hard Drive SATAII 7200RPM 16MB Cache - OEM
1 x XFX 8800GTS 320MB DDR3 Dual DVI TVO PCI-E Graphics Card
1 x Scythe Black Kama Panel Multimedia Fan Controller/Card Reader 5.25" Bay
For a start the motherboard does not have a speaker for fault finding, i start the computer and it turns on and cuts out it then turns itself back on with all the fans and nothing is displayed
Next i took the g/c to my dads pc and it works to problem and yes he has the same moniter? Hmmmmmm......
I know go back home plug it back in and nothing still. i i unplgged everything back to basics cpu/mono/g,c and still nothing.
I think its the motherboard but i am not sure can anyone help cause i am thinking of returning the board and if it aint faulty i have to pay for it to come back.
