Tom's Hardware > Forum > CPU & Components > CPUs > Will the Thermalright - Ultra 120 eXtreme work on my motherboard?
Forum CPU & Components : CPUs - Will the Thermalright - Ultra 120 eXtreme work on my motherboard?
My friend just helped me build this rig:
Intel Core 2 QUAD Q6600 Quad Core 2.4GHz 8MB(2x4MB) Socket 775
Gigabyte GA-P35-DQ6 iP35 4DDR2-DIMM 2PCI 5PCIe SATA Socket775 ATX
And my old Scythe Ninja won't fit on the motherboard because that silentpipe technology that the gigabyte motherboard uses has a backplate (think thats the right word) right underneath the cpu.
So the cooler im using right now is way to loud and Im really keen on getting the Thermalright Ultra 120 eXtreme but im not sure it will fit since the scythe didn't. Do you guys know if it can be fitted or am I stuck with this thing im using right now?
Sponsored Links
I think the Ultra has a backplate too. Have you gone on Newegg and looked?
You aren't stuck, since you can get coolers that fit in the same way the stock one does, such as the Arctic Cooling Pro 7.
Reply to nukchebi0
http://www.thermalright.com
Click on the Heatsink on the left, then on the 120 Ultra Xtreme, then click on the Compatibility list on the page and check.
Reply to darkguset
The Thermalright does use a backplate. I'm not sure how differently configured your Mobo is when compared to mine (gigabyte p35c-ds3r) but I had absolutely no issues with mounting it. My only scare came from my case (antec 900) but once everything was seated it fit, albeit with little or no extra elbow room.
Reply to trevorblain
There are 507 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 13:08 OvrClkr won the Overclocking badge
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
