Case Rear I/O panel question
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Case Rear I/O panel question
Hi,
I'm putting together a new system....I've been spending some time looking at the case and the motherboard that I like and am concerned about the compatibility of the motherboard and the rear I/O panel.
The motherboard I like is Asus P5K-E
http://www.newegg.com/Product/Prod [...] 6813131196
The case I like is the RaidMax Smilodon:
http://www.newegg.com/Product/Prod [...] 6811156062
It is an ATX form factor motherboard and an ATX case. However, if you look at the picture of the mother board and the case, you'll see that the case's rear I/O panel looks nothing like the I/O ports on the motherboard.
My question: is it possible to remove the rear I/O panel cover from the case entirely without damaging the case?
Any pointers on how to do this?
Thanks in advance...
Sponsored Links
RickyBobby1 wrote :
Hi,
Your MB will come with it's own I/O shield. Just pop out the shield provided with your case and install the correct one supplied with your MB.
Reply to badge
Thanks...just wanted to make sure I wasn't going to have to do major surgery right off the bat...
Reply to RickyBobby1
Contents of your MB. Just pop the one out of the case and install this one.
http://img227.imageshack.us/img227 [...] 101og2.jpg
Reply to badge
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Case Rear I/O panel question
There are 1362 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
