So I find posts saying the cooling is fine for this card, but mine apparently isn't. I have the PNY stock cooler on it and it runs hot. While playing the Crysis SP demo I reach 92 degrees Celsius a few minutes in and it stays that way during play.
This card USED to trigger BSOD until I clocked the card down to what a 8800gtx normally runs at, undoing the PNY factory's overclocking.
Is there a good 3rd party cooler I can get for this card? How tricky is it to pull the cooler off the card and redo the thermal paste? I may try using some arctic silver first with the current cooler to see if that helps. 92 just seems awful high.
Raddix
Raddix
