Case Cooling
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Case Cooling
I have a Thermaltake Tsunami Dream (with window). I'm running a Q6600 and EVGA 880GTX 768 card.
I'm going to replace the front and rear 120mm fans with something a bit better. Was thinking of Hiper 120mm ones.
I was wondering about the 90mm fan that comes on the side window. Is there a way to change this to a 120mm? I'm not the handiest of people and don't fancy taking a Dremel to the window!
Also, I have removed the cable and top USB/speaker/firewire ports that come out of the top so might stick a fan in that too.
Lastly, is there a programme that will allow me to monitor the temp inside the case? Or, failing that, something I can add to do this?
Ta!
------------------------------ Intel Core 2 Quad Q6600 G0 Stepping
MSI P6N SLI Platinum nForce 650i
OCZ 2GB Kit (2x1GB) DDR2 800MHz
EVGA 8800GTX 768MB GDDR3
Sponsored Links
If your system is running stable, I wouldn't worry too much about case temps. If you have a stability issue, I would look at water cooling. I personally hate fan noise, so that's my number one issue after stability.
Reply to o1die
These adapters come in 90mm to 120mm also. Computer/Electronics stores like Fry's has them in stock usually.
http://www.directron.com/dir80120.html
Reply to badge
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Case Cooling
There are 945 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
