I just upgraded my CPU cooler on an brisbane 4000. With the stock cooler I was at around 35c idle and 59c peak full load on orthos with an OC to 2.5GHz from 2.1GHz stock. Now I have a Asus Triton 70 CPU cooler that is over all alot better for my cases air flow. My load temps dropped by 10c but my idle temps went up. My full load temps are still fine even with a new OC of 2.74GHz with a load temp of 52c peak but my idle temp is 38-40c which I think is kind of high for idle temps esspecially with a good cooler and lots of case airflow. At first I thought mabey to much thermal grease but if that were the case wouln't I have higher load temps also? Cool and Quiet enabled btw, but I did just disable that to see what my temps were like without it and its the same pretty much.
Any thoughts?
Any thoughts?
