Greetings,
I am not familiar with the technical aspects of a motherboard and I am stumped with a problem!
I was given an HP Pavilion 4450 computer that would not turn on. I thought it would be worth checking the power supply and if it worked, I would let my 5 year old play pre-school games on it. The power supply in it was an ATX100-5. I purchased what was described as an ATX100-5 on eBay, but received an MICRO ATX (275W - 12V) power supply by Kenwell Electronics. (They claim it is a replacement power supply for the ATX100-5)
I connected it to the motherboard according to the manual for the Asus MEB-VM motherboard but when I power on the computer, the motherboard stays on but the monitor will click on for about a second but then turns off. I have tried this with two different monitors with the same results.
I am only connecting 4 of the power supply connectors: the motherboard, the hard drive, the slave drive and the floppy drive. There are two other connectors on the power supply but the MEB-VM manual doesn't say anything about connecting them or where to connect them, though one of them is a four pin connector that says "HP Video Power". I just don't see a four pin connection on the motherboard for it.
I don't know where to go from here, so I would be grateful for any help or suggestions.
Thanks!
John
Thanks!
John
