Archived from groups: alt.tv.tech.hdtv (More info?)
Several months ago I bought a Sony KDF-60XS955. The set has developed a
problem that causes it to not be able to receive several channels at
times, with the black screen displaying "no signal"
I am using a cable card with Cox Cable. I also have an over the air
antenna which receives local HDTV broadcasts.
Originally suspecting the cable co. hardware, I have had several cable
cards replaced, and that didn't solve the problem.
Sometimes a transmission will suddenly go black and "no signal" will
appear on the black screen. At other times there will be no sound with
a good picture.
The problem can usually be solved by turning the tv off and on again,
but it can re-occur while watching broadcast. (most of the times at
critical times of a plot)
Another thing I've noticed is that if the HD Network (eg NBC or ABC)
cable transmission signal is not being received and I switch the remote
to the over the air (antenna) equivalent station isn't either. The
other tv's on the cable have no problems.
It looks like this is a Sony problem, and I was wondering if it is a
known problem that others have had.
Thanks for any help or comments!
Yeah, just about every problem you talk about here with your Sony 955 and
the cablecard signal I have also had, in slightly different form, with my
955 and the cablecard signal from Time-Warner Cable in Austin. After a
couple of months, we finally threw in the towel on cablecard and went with a
Scientific Atlanta 8300 HD-DVR cable box. Huge improvement, in every way!
No more loss of signal, 2-way service with the cable company if we want it,
a program guide and a 2-tuner DVR that, even with a few irritating quirks,
records HD beautifully, just like the original.
We had two kinds of cablecard dropouts: "Cable Card Error 161-6", which
required one of two things to fix, either re-seat the CC (turn off TV, pull
card, put back in, turn TV back on) or let the set re-find all the digital
channels (takes forever). The frequency of that seemed to lower after I
installed a firmware upgrade for the TV set (ask about that for your set).
The other variety of dropout was just a sudden freeze and go-to-black of
cablecard signal for all the "HD Tier" extra stations, HBOHD and sometimes
other stations, but not always. Often, the local HD channels would continue
without any problem.
Time-Warner worked on the problem and we went through a couple of cards but
we still got dropouts. They said there were just problems getting the cable
company's computers, the cablecards, the TV sets, etc. all to work together.
First generation technology. Hey, that's what they say. They also say that
engineers representing various interests are trying to work out problems.
And that Panasonic TV sets seem to work best with the cc system TW uses.
Bottom line, with the box -- get the 8300 DVR if you can -- your experience
will be MUCH enhanced for a few extra dollars a month. It hooks up to the
955 via HDMI cable, if you want, btw. And has optical digital OUT for your
receiver, so you send good digital audio out for all channels. AND -- the
SD picture through it is as good as it was with cablecard.
Great picture with this set, don't you think? We love it. But did you ever
try to get "live color" in "Advanced" video settings to work? When I set
that to ON, it fills all the light areas with dark, squirming worms. The
set came that way from the factory and I had to find the problem and turn it
off. That's the only significant problem I have ever had with it and, since
the "live color demo" doesn't appear to add anything I can actually see
anyway (except for the worms), it's not really significant.
mack
austin
<mouln@yahoo.com> wrote in message
news:1113830594.871551.265670@f14g2000cwb.googlegroups.com...
> a good picture.
Question?? Have either of you had SONY Service checkout your respective
teles? Or try another Q_Box "AKA Cable Card Tuner" in your set?? May I
presume that you have also tried more than just one cable card from your
supplier to make sure it may not be card or signal related.<
> RE: Austin: Probably not signal related but either card or Q_Box related.
> Just a question as to what diagnostics have actually been done on the
> equipment inclusive of the teles?
"Mack McKinnon" <MckinnonRemoveThis@tvadmanDeleteThisAsWell.com> wrote in
message news:joQ8e.9917$h6.4385@tornado.texas.rr.com...
> a Scientific Atlanta 8300 HD-DVR cable box. Huge improvement, in every
> way! No more loss of signal, 2-way service with the cable company if we
> want it, a program guide and a 2-tuner DVR that, even with a few
> irritating quirks, records HD beautifully, just like the original.
> pull card, put back in, turn TV back on) or let the set re-find all the
> digital channels (takes forever). The frequency of that seemed to lower
> after I installed a firmware upgrade for the TV set (ask about that for
> your set). The other variety of dropout was just a sudden freeze and
> go-to-black of cablecard signal for all the "HD Tier" extra stations,
> HBOHD and sometimes other stations, but not always. Often, the local HD
> channels would continue without any problem.
> but we still got dropouts. They said there were just problems getting the
> cable company's computers, the cablecards, the TV sets, etc. all to work
> together. First generation technology. Hey, that's what they say. They
> also say that engineers representing various interests are trying to work
> out problems. And that Panasonic TV sets seem to work best with the cc
> system TW uses.
> experience will be MUCH enhanced for a few extra dollars a month. It
> hooks up to the 955 via HDMI cable, if you want, btw. And has optical
> digital OUT for your receiver, so you send good digital audio out for all
> channels. AND -- the SD picture through it is as good as it was with
> cablecard.
> ever try to get "live color" in "Advanced" video settings to work? When I
> set that to ON, it fills all the light areas with dark, squirming worms.
> The set came that way from the factory and I had to find the problem and
> turn it off. That's the only significant problem I have ever had with it
> and, since the "live color demo" doesn't appear to add anything I can
> actually see anyway (except for the worms), it's not really significant.
> mack
> austin
>> a good picture.
"Art" <plotsligt@comcast.net> wrote in message
news
_mdnRLn2_gmnfnfRVn-ig@comcast.com...
Can't speak for the other guy, but I had SEARS service check out the TV
(they hold the extended warranty and do the service for SONY). They were
the ones who acquired the firmware upgrade from Sony set that I installed.
I tried 2 cablecards in all.
Personally, I never had any problem with OTA stations and did not find that
my OTA reception related to the cablecard reception problems in any way.
Time-Warner Cable here readily admits that they are not yet able to provide
very good service to cablecards, calls the technology very early stage and
says Time-Warner engineers are working with Scientific Atlanta and the TV
set manufacturers to iron out problems. So they say.
I don't understand your second question.
mack
austin
>> with a Scientific Atlanta 8300 HD-DVR cable box. Huge improvement, in
>> every way! No more loss of signal, 2-way service with the cable company
>> if we want it, a program guide and a 2-tuner DVR that, even with a few
>> the cable company's computers, the cablecards, the TV sets, etc. all to
>> work together. First generation technology. Hey, that's what they say.
>> They also say that engineers representing various interests are trying to
>> work out problems. And that Panasonic TV sets seem to work best with the
>> cc system TW uses.
>> cablecard.
>> I set that to ON, it fills all the light areas with dark, squirming
>> worms. The set came that way from the factory and I had to find the
>> problem and turn it off. That's the only significant problem I have ever
>> had with it and, since the "live color demo" doesn't appear to add
>> anything I can actually see anyway (except for the worms), it's not
>> really significant.
>> mack
>> austin
>>> a good picture.
Art & Mack,
Thanks for your replies!
I will call Sony to have this checked out, but want to do my homework
before I call Sony.
I am not familiar with the Q box.
Is that a separate tuner built into the XS specifically designed to
work with a cable card?
What other hints are there that it might be a Q Box problem with the
Sony?
I have had occasional signal dropouts or pixelization problems with the
cable box before, but not as many.
Art: Are you a tech familiar with the XS series?
if so is this is a common problem with the first generation of cable
cards or a problem with the Sony. Mack's experience tends to back this,
but then again this Q box might be the real problem
Mack: Did your problems end when you went back to the box?
Thanks again for your help guys
Jim
Mack McKinnon wroteQ :
> news
respective
May I
your
TV
were
installed.
find that
way.
provide
stage and
the TV
> mack
> austin
related.
the
wrote in
955 and
with my
After a
went
improvement, in
company
few
which
TV,
all the
lower
that for
and
stations,
local HD
cards
getting
all to
say.
trying to
with the
> >> cc system TW uses.
It
optical
for all
with
> >> cablecard.
did you
When
squirming
the
have ever
not
> >> really significant.
> >> mack
> >> austin
developed a
at
air
cable
will
with
> >>> a good picture.
again,
at
ABC)
remote
The
is a
Art & Mack,
before I call Sony.
Sony?
Jim
> news
respective
May I
your
TV
were
installed.
find that
way.
provide
stage and
the TV
> mack
> austin
related.
the
wrote in
955 and
with my
After a
went
improvement, in
company
few
which
TV,
all the
lower
that for
and
stations,
local HD
cards
getting
all to
say.
trying to
with the
> >> cc system TW uses.
It
optical
for all
with
> >> cablecard.
did you
When
squirming
the
have ever
not
> >> really significant.
> >> mack
> >> austin
developed a
at
air
cable
will
with
> >>> a good picture.
again,
at
ABC)
remote
The
is a
FYI: Authorized SONY as well as many other manufacturers devices. Seen a few
strange problems with the implementation of the Cable Card via both major
cable suppliers in our geographic area. {Greater Detroit, South-East
Michigan, North West Ohio}.<
> Mack, your response included the fact that the devices indeed had been
> subjected to through diagnostic via both the supplier [Time-Warner] and a
> SONY authorized servicer [SEARS}.<
>The "Q-Box" is what SONY refers to as their interface for the Cable Card
>PCMCIA and the ATSC Tuner within their sets. <
>Problems have been generated both by the service providers and the
>products, some of the technicians for the suppliers have not endured
>appropriate training, IMHO, to be actually dealing with these devices yet.
>That is, they seem much more comfortable just installing the Set Top Boxes
>and connecting them either with component or composite cables. God forbid
>if you have a HDMI connector and ask them to provide the appropriate
>interface cable let alone a cable card.<
> Also,a lot of the service technicians for the authorized facilities are
> green when it comes to this technology, not having the ability or desire
> to learn about these item. The manufacturers do provide training, BTW!!<
>As with almost all new technology, especially in the home entertainment
>marketplace, it seems the manufacturers testing and proving grounds are
>actually in our respective homes. Thanks again Gents for your responses,
>hopefully this technology, and future items come forth without the trauma
>and trepidation already being endured.
news:1113859377.547903.156890@g14g2000cwa.googlegroups.com...
> Art & Mack,
> before I call Sony.
> Sony?
> Jim
>> news
> respective
> May I
> your
> TV
> were
> installed.
> find that
> way.
> provide
> stage and
> the TV
>> mack
>> austin
> related.
> the
> wrote in
> 955 and
> with my
> After a
> went
> improvement, in
> company
> few
> which
> TV,
> all the
> lower
> that for
> and
> stations,
> local HD
> cards
> getting
> all to
> say.
> trying to
> with the
>> >> cc system TW uses.
> It
> optical
> for all
> with
>> >> cablecard.
> did you
> When
> squirming
> the
> have ever
> not
>> >> really significant.
>> >> mack
>> >> austin
> developed a
> at
> air
> cable
> will
> with
>> >>> a good picture.
> again,
> at
> ABC)
> remote
> The
> is a
> a good picture.
There have been many problems with cablecard applications on most brands of
TVs, cablecards, and with most cable vendors. Most manufacturers of the
sets and the cablecard have gone through several generations of software
upgrades. Contact your Sony ASC and your cable company and have them verify
that your set and the cable system in your area is using the latest software
for your cablecard.
Cox has recently upgraded the software here in Gainesville for the SA card
and most of the problems cleared up. If you can be patient and diligent,
the result will likely be significantly better performance in terms of
picture quality than using external boxes.
Unfortunately, cablecard implementation has been shaky. The cable operators
don't really know much about how they work and the set manufacturers, cable
operators, and card vendors all have to work together to solve the problems.
The communication between them all has varied greatly and depends largely on
getting the right people to talk to each other. The control point that can
effect the most improvement in the matter is usually the cable operator.
For any one party to say that the problem is with "your set", "the cable
company", or "the cablecard", is irresponsible. All three have to be
working together properly for the system to work. I spent dozens of hours
communicating with all three levels trying to get problems worked out for
our clients. Fortunately, the local Cox operator was very cooperative in
figuring it all out. Ultimately the deployment of the SA software was the
most important part.
Leonard
Yes, I am currently using an SA 8300 HD-DVR cable box input to the TV via
HDMI for video and optical digital cable for audio. No problems at all,
except those from the local stations or the networks on occasion, of course.
Also get good OTA from the stations that provide good signals, via a Gemini
set-top antenna, placed near a window, as always.
mack
austin
> Jim
>> news
> respective
> May I
> your
> TV
> were
> installed.
> find that
> way.
> provide
> stage and
> the TV
>> mack
>> austin
> related.
> the
> wrote in
> 955 and
> with my
> After a
> went
> improvement, in
> company
> few
> which
> TV,
> all the
> lower
> that for
> and
> stations,
> local HD
> cards
> getting
> all to
> say.
> trying to
> with the
>> >> cc system TW uses.
> It
> optical
> for all
> with
>> >> cablecard.
> did you
> When
> squirming
> the
> have ever
> not
>> >> really significant.
>> >> mack
>> >> austin
> developed a
> at
> air
> cable
> will
> with
>> >>> a good picture.
> again,
> at
> ABC)
> remote
> The
> is a
Art,
Interesting to know what you meant by the "Q box".
Technicians "green" on cablecard? When a SEARS guy came out and I told him
I had a cablecard, he replied, "What's a cablecard?" Later, SEARS
apologized and told me that they would send out someone else, with more CC
experience in the future. Who knows, maybe they actually have someone like
that. But you see why I just went ahead and installed my own Sony firmware
upgrade.
Time-Warner Cable knows a bit more about CC's but, as yet, not enough.
Apparently, the cable companies, set manufacturers, and authorized service
providers are not on the same page with CC yet, or near it. Time-Warner
here claims that Panasonic sets work best with CC's. In any case, it is an
early technology -- based on my experience, for most people it's too early
to mess with it, if you have a good second choice. For me, the SA 8300
HD-DVR turned out to be a MUCH better way to go.
mack
austin
news:N-Cdndlra6DEovnfRVn-qQ@comcast.com...
> few strange problems with the implementation of the Cable Card via both
> major cable suppliers in our geographic area. {Greater Detroit, South-East
>> Art & Mack,
>> before I call Sony.
>> Sony?
>> Jim
>>> news
>> respective
>> May I
>> your
>> TV
>> were
>> installed.
>> find that
>> way.
>> provide
>> stage and
>> the TV
>>> mack
>>> austin
>> related.
>> the
>> wrote in
>> 955 and
>> with my
>> After a
>> went
>> improvement, in
>> company
>> few
>> which
>> TV,
>> all the
>> lower
>> that for
>> and
>> stations,
>> local HD
>> cards
>> getting
>> all to
>> say.
>> trying to
>> with the
>>> >> cc system TW uses.
>> It
>> optical
>> for all
>> with
>>> >> cablecard.
>> did you
>> When
>> squirming
>> the
>> have ever
>> not
>>> >> really significant.
>>> >> mack
>>> >> austin
>> developed a
>> at
>> air
>> cable
>> will
>> with
>>> >>> a good picture.
>> again,
>> at
>> ABC)
>> remote
>> The
>> is a
Unfortunately, Time-Warner Cable here seems to be at a dead end in terms of
figuring out what the CC problems are. They do work on it, and have made
some improvements but, in the end, they themselves say they don't really
understand the problems and are unable to fix them. They have a tendency to
blame everything on the interface of CC, cable company and TV set. They
like Panasonics; they don't like Sony's.
Also, you have the problem (at least, I do) that even if your CC works
great, in terms of signal, you have no program guide from the cable company
and no HD DVR. I was used to my Panasonic E80 SD DVR and loathe to give up
the time-shifting capability when I went to HD. Now, with the SA 8300 HD
DVR, even though it has its share of irritating quirks (that they could
probably fix with one firmware upgrade if they really wanted to!) it's a
GREAT thing to have a (1) good signal, both HD and SD, (2) a program guide
and (3) the ability to just punch R on the remote and record 1 or 2 shows
right off the guide, then watch them back, looking just like the original.
Didn't get any of that with the CC.
mack
austin
"Leonard Caillouet" <no@no.com> wrote in message
news:3r69e.16403$B93.2016@lakeread06...
>> a good picture.
> of
> verify
> software
> for your cablecard.
> operators
> cable
> problems.
> on
> can
> Leonard
I have been watching developments on the cable card front for some time.
The cable companies are not exactly thrilled about one way cards and I
suspect that they might be secretly pleased when they do not work. They may
even have a little something to do with it. The box rental and the
possibility of program ordering bode well for cable revenue.
As for myself, I couldn't care less about a programming guide or pay per
view or any of it. You don't need the card for unscrambled channels and as
soon as the cable company has the card working well, I intend to buy an HDTV
with one way cable card capability for the extra pay HDTV channels I might
want to purchase. Right now, the company is sending the customer to a
different location to actually acquire the the card (a contractor?).
They're not making it easy and a person is more likely to say, "Oh, give me
the box."
People at the AVS Forum say that the picture is significantly improved when
it uses the card and doesn't go through the box. That is because the
electronics in the set are better than the cable box.
message news:EDc9e.19494$hu5.10941@tornado.texas.rr.com...
of
to
company
up
> mack
> austin
> >> a good picture.
> > of
> > verify
> > software
> > for your cablecard.
card
diligent,
> > operators
> > cable
> > problems.
largely
> > on
> > can
hours
for
in
the
> > Leonard
My Cable Card in our Mitz 62725 works perfect. I had one problem initially
with occasional lockup until a recent firmware upgrade(about 2 months ago).
Now it's fine. We have comcast...if that matters. I think a lot of this is
the TV manufacturers fault. They should be able to interface cable
company's known technology......as far as my "knowledge" goes, the CC is
simply a descrambling device? Correct?
Don
"Stan" <ssum9160@adelphia.net> wrote in message
news:EbednX8NXND5-PjfRVn-jA@adelphia.com...
> may
> as
> HDTV
> me
> the box."
> when
> of
> to
> company
> up
>> guide
>> original.
>> mack
>> austin
>> >> a
>> >> a good picture.
>> >> remote
>> > brands
>> > of
>> > the
>> > software
>> > verify
>> > software
>> > for your cablecard.
> card
> diligent,
>> > operators
>> > cable
>> > problems.
> largely
>> > on
>> > can
>> > operator.
>> > cable
> hours
> for
> in
> the
>> > Leonard
I found that using a cablecard greatly improved my SD reception over a basic
HD cablebox from Time-Warner. The TV set did a better job of converting the
SD picture than that box did. But when we eventually went to an SA 8300 HD
DVR cable box, the SD reception through it was as good as it was via the
cablecard, so that reason for using a CC went out the window.
Personally, I find having an onscreen cable guide to be very convenient.
And I had gotten used to a DVR, having used an SD Panasonic E80 for over a
year to time-shift programs, before we got our HDTV.
As for pay-per-view, there is, in theory, some good things about having "On
Demand" channels, even if you don't ever buy PPV events. Some of the OD
channels are free and if you like OD cooking shows or decorating or
whatever, you can pick and choose through them. We have an On Demand HD
Movie channel where you can watch HD movies @ $4.95 each. If they had a
larger selection (only 9 last time I looked) I would probably buy one
occasionally. Worth an extra buck or two to not have to go rent a DVD and
the picture is better.
mack
austin
> may
> as
> HDTV
> me
> the box."
> when
> of
> to
> company
> up
>> guide
>> original.
>> mack
>> austin
>> >> a
>> >> a good picture.
>> >> remote
>> > brands
>> > of
>> > the
>> > software
>> > verify
>> > software
>> > for your cablecard.
> card
> diligent,
>> > operators
>> > cable
>> > problems.
> largely
>> > on
>> > can
>> > operator.
>> > cable
> hours
> for
> in
> the
>> > Leonard
I tried replying earlier but haven't seen it post. I may have done
something wrong so, I'll try again.
I too have the Sony KDF-60XS955 (bought 11/04 Manuf. 10/04) and a few
days ago it lost a few of the HD channels that it previously had. I
thought Adelphia was scrambling of blocking, but why not all the HD
channels? So I rescanned. The TV found and put back in the same
location all the channels except NBC-D which it located a 0.0. The next
day I noticed I could no longer "channel up & down" via the remote or
the buttons on the TV. I went into the menu where I found it had
forgotten all the channels. I recanned yet again. I found them all
again and still had NBC-D at 0.0. That lasted a few hours when it
couldn't change channels and lost its memory. I called Sony then Best
Buy (I have an extended warranty and figured this is strike one on the
lemon clause, let them handle it). Yesterday the TV responded to ch up
& dn but would only tune between 82.1-82.80 with only one live channel
82.6. All others were "No Signal". Also durning one of my explorations
of the menu system, the menu "collapsed" into a mass of veticle lines!
Best Buy comes today to look at my "audio problem"!!! Grrrrr. I
explained to the tech this AM what exactly is going on. I'm glad to
know from an earlier post that there's a firmware update, I'll push for
that. But I have no hope he'll be bringing a replacement tuner
card/board whatever. My last Sony RPTV had 9 repairs under the 5 year
contract, but never quite made it to lemon status. I wonder how this
one will do. I'm still wondering why I bought another Sony. Don't
ask!?! :-(
I haven't had any problems such as you describe with my 955. But the way
you describe this seems kind of weird to me. It sounds as though you are
trying to pull in cable channels in the same way you would pull in OTA
channels. I think you can do that with "in the clear" HD channels on a
basic cable hookup. Maybe that is what you have.
But if you are trying to pull in HD channels provided by Adelphia, they
should be coming in as something like "Ch. 1501, Ch. 1502" or whatever --
that sort of thing. That is true even with a cablecard, which you did not
mention, so I doubt you have a cablecard. The tuned numbers with decimals
and all that have to do with pulling in OTA reception using an antenna.
With a cable box, the cable company does that for you and transmits the
channels as regularly numbered cable channels.
How do you have your cable hooked up? With a cablecard (or, I suppose, if
you are taking "in the clear" HD channels off basic cable) it goes into the
"cable" input, not the "antenna" input. Obviously, you hook up an OTA
antenna into that one. With a cable box, the cable normally goes into the
cable box and then you use component or HDMI to connect to one of your TV
set's inputs. You should be able to just tune to the HD channels, as they
show up on the Adelphia guide.
mack
austin
"Joe in Los Angels" <josephspiegel@gmail.com> wrote in message
news:1114106743.204294.78680@z14g2000cwz.googlegroups.com...
> ask!?! :-(
Hi Mack,
I have the cable going straight into the set's CATV in. The TV can
capture all of the analog channels and many of the digital (but not all
nor any pay)channels including the local HD channels. (Until the other
day that is) I also have a "rabbit ears" set up to get the OTA HD
channels Adelphia doesn't provide (The KTLA-WB and KOCE PBS Orange
County) as of yet. I also have a Moxi Cable PVR box for the pay HD
channels HBO, ESPN and Discovery that I get, and to record the Local HD
channels they provide.
The Best Buy tech just left. He's ordering the main circuit board as he
feels it's more a memory/proccessing issue than the tuner. Could be,
I'll let him try that. I've got a thread going in the AVS Forum RPTV
section on this issue. Between these two forums I hope we find an
answer.
Joe
way
are
OTA
a
they
whatever --
did not
decimals
antenna.
the
suppose, if
into the
OTA
into the
your TV
they
> mack
> austin
few
next
or
Best
the
up
channel
explorations
lines!
for
year
this
> > ask!?! :-(
There are 610 identified and unidentified users. To see the list of identified users, Click here.
