Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > what is the best cpu water block for intell q6600 socket 775?
Forum Overclocking : Cooler and Heatsinks - what is the best cpu water block for intell q6600 socket 775?
What is the best cpu water block for intel q6600 socket 775? That will give me the most heat Dissipation
Sponsored Links
Here you go:
http://www.dangerden.com/store/pro [...] =92&page=1
I have a friend who has one and it works real well.
-ouch1
Reply to ouch1
If you went with either the EK Supreme, Dtek Fuzion, DangerDen MC-TDX or the Apogee GTX you couldn't go wrong. Those are some of the top performing CPU Waterblocks on the market.
Dtek offers a nozzle kit as an extra for the Dtek Fuzion that splits the waterstream so that it hits both dies on the quad-core with much higher pressure than is standard.
------------------------------ Swiftech Mcres-Micro Reservoir, MCP655 Pump, D-tek Fuzion CPU Waterblock w/nozzle kit, Thermaltake Toughpower 1200, Swiftech Stealth GPU Waterblock, 2 external dual 120mm rads (each with four 120mm fans in "push-pull" )
Reply to phreejak
There are 1152 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
