I'm building a new system, and I have a few questions. Here is what I'm leaning towards:
cpu - Intel Core 2 Quad Q6600
gpu - 8800gts 640mb
motherboard - MSI P6N SLI Platinum
memory - PDC22G6400LLK
hdd - Western Digital Caviar SE16 WD7500AAKS
optical - Sony NEC Optiarc 7170 SATA
case - Raidmax Smilodon
power supply - ?
Now, I basically mismatched stuff from the mid-cost and low-cost, taking most from the mid. I do want to keep a low price though. This pc will be used for gaming, developing, some media (but not creating), and other everyday stuff.
I know that games don't benefit much by a quad core now, but I wonder if they might start to soon. Also, if I'm coding I think it might be nice to have a few cores. I don't plan on overclocking, so I'm just going to use the cooler it comes with. What do you think, good idea?
As for the gpu, I see that the 8800gts 320mb version is at about $280, the 640mb one I can get for $370, and the gtx is at $500. The gtx is pricey, and I don't think I want to spend that much money on it. The 640mb I think is more reasonable. I have a 21" lcd that runs at 1680x1050. I would like to play games at that resolution. Do you think this is reasonable?
The power supply is where I'm really stuck. I don't want to spend a lot, and I'm not sure how big I need it. I like the Fortron Source AX450-PN, and it's only $60, which is good. I'm not sure if 450w is enough though, I might add another hdd in the future, but thats about it. The mid cost system recommends the AeroCool Zerodba 620W, but I don't think I need that much power. It's also $125 dollars, which is double the other one. Do you think the Fortron would be enough, or do I need to get more watts? Also, if I need more, about how much more, and are there any supplies you would recommend?
For the sound, I'm thinking of just using onboard. I was looking at the X-fi, but it annoys me that they don't have digital connections on the card. It looks like people really have to go through hoops to get it connected. I'm going to use some 5.1 speakers I already have, logitech's z-5500's, and they have optical and coax input. The motherboard I'm looking at has Realtek ALC888 HD Audio and optical connections right on it. Is this good enough, or would you recommend getting a soundcard?
If you see any other problems with this build, things I'm forgetting, or ways to improve it without adding much cost, let me know.
Thanks,
John
gpu - 8800gts 640mb
power supply - ?
Thanks,
John
