Need advice on the new system I'm about to build!!!
Last response: in Systems
October 5, 2007 7:10:26 PM
ASUS 18X DVD±R DVD Burner with LightScribe and 14X DVD-RAM Write Black SATA Model DRW-1814BLT - OEM
http://www.newegg.com/Product/Product.asp?item=N82E1682...
Thermaltake Armor Series VA8000BWS Black Aluminum / Steel ATX Full Tower Computer Case - Retail
http://www.newegg.com/Product/Product.asp?item=N82E1681...
$149.99
Western Digital Raptor WD1500ADFD 150GB 10,000 RPM Serial ATA150 Hard Drive - X2
$359.98
($179.99 each)
BFG Tech BFGR88768GTXOCE GeForce 8800GTX 768MB 384-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card - Retail
$529.99
CORSAIR Dominator 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model TWIN2X2048-8500C5D - Retail
$362.00
($181.00 each)
EVGA 122-CK-NF68-A1 LGA 775 NVIDIA nForce 680i SLI ATX Intel Motherboard - Retail
$224.99
ZALMAN RESERATOR 1 Fanless Water Cooling System (Reservoir+Radiator+Water Pump) - Retail
http://www.newegg.com/Product/Product.asp?item=N82E1683...
$169.99
ABS Tagan ITZ Series ITZ1100 ATX12V / EPS12V 1100W Power Supply - Retail
Item #: N82E16817814002
Return Policy: Standard Return Policy
http://www.newegg.com/product/Product.asp?item=N82E1681...
Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Item #: N82E16822148140
Return Policy: Limited 30-Day Return Policy
http://www.newegg.com/product/Product.asp?item=N82E1682...
-$79.99 Combo
$379.98
$299.99
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Processor Model BX80562Q6600 - Retail
$279.99
More about : advice system build
October 5, 2007 8:39:37 PM
I'd save $107 and get this PSU instead:
PC Power & Cooling Silencer 750 Quad (Black) EPS12V 750W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703009
Tagan is a good brand, but so is PC P&C, and that Silencer is good enough even for 8800 GTX SLI.
Edit: never mind, I didn't realize it was a combo. Nice, good find!
October 6, 2007 1:00:21 PM
that Tagan is fine , if he can get ,then let him have it and enjoy it
although yes , Silencer is a very fine PSU
