After a lot of research, I found the pieces I'd like to use in my new budget build, the parts are on their way from Newegg and its almost time to put it all together. This is my first time building a PC and it doesn't seem all that hard, however I have a few things I would like to get covered.
First of all, my setup:
Gfx: EVGA 256-P2-N615-TX GeForce 7600GT 256MB 128-bit GDDR3 PCI Express x16 SLI Supported Video Card
CPU: AMD Athlon 64 X2 5200+ Windsor 2.6GHz Socket AM2 Processor Model
PSU: FSP Group (Fortron Source) FSP400-60THN-R ATX 2.0 400W
Mobo:MSI K9VGM-V AM2 VIA K8M890 Micro ATX AMD Motherboard
Ram: WINTEC AMPO 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel
I am aware that some things could be better, but this however is my first build and will only be keeping me held over for a few months or so. I feel pretty confident about putting it together (assuming the parts come shipped ok), but I don't however understand being grounded, I bought a Rosewill Wrist Strap for precaution, but I am not sure how they work exactly, is that the only hand that is free to touch parts or what? Also, I am not sure where there is a ground wire in my house and would latex gloves be a problem to wear or is it something I should avoid? Thanks.
Edit: BTW I do not plan to overclock as I don't really know much about doing it, so I plan to hold off until I understand it more.
