Hi all,
I recently finished my new build, using the Asus Blitz Formula (P35) mobo. I'm having a really peculiar POST issue. I have 4x 1GB sticks of OCZ PC2-9200 FlexXLC Edition. If I put in two sticks, the RAM runs fine at DDR2-1066. If I put in three sticks, I can only run at DDR2-667. If I put in all four, it fails POST at DETDRAM. It's not a bad slot or memory module, as any combination will yield the same results. It's not a PSU issue; I have an 850 watt PSU. I've tried underclocking the RAM to 800 and 667, and I've tried increasing voltage to the NB and RAM, but no matter what I do, I can't get it to POST with four DIMM's! I know the P35 chipset has stability issues with 4x at 1066, but this isn't a matter of stability. I'm waiting on both tech support and forum at Asus. No luck there so far, so I was hoping someone here might have a brilliant solution to my problem.
Oh yeah; it's liquid cooled, so I can't really try the RAM in another board or try different RAM in this board without incurring about four hours of work. I'm going to try some different RAM in my motherboard (should be able to stretch the tubing far enough) if I can get my hands on four modules.
Thanks in advance,
Sirius
Thanks in advance,
Sirius
