Hello all...long time lurker first time poster! I am going to build another gaming system (plan on OC'ing) and I think I have it pretty much nailed down.
http://www.newegg.com/Product/Product.asp?item=N82E16811156062 for a case. I know I can buy this without a junk power powersupply but I have an old system that needs one and for $10 it is perfect.
http://www.newegg.com/Product/Product.asp?item=N82E16817703005 for the power supply.
http://www.newegg.com/Product/Product.asp?item=N82E16814130080 for a GPU.
http://www.newegg.com/Product/Product.asp?item=N82E16820148070 either 2 of these for memory or 2 of these http://www.newegg.com/Product/Product.aspx?Item=N82E16820146565 is it worth it for the tracer?
http://www.newegg.com/Product/Product.asp?item=N82E16813128064 this for a MOBO or upgrade to this http://www.newegg.com/Product/Product.aspx?Item=N82E16813131181 opinions please.
http://www.newegg.com/Product/Product.asp?item=N82E16819115017 this for a CPU
and I have existing GIGABYTE water cooling so I will add this http://www.newegg.com/Product/Product.asp?item=N82E16835128016 to my new graphics card I will have to call them and get the right bracket.
Also I would like a little information on the difference between SATA 3.0 and a Raptor drive. I understand that the raptor spins at 10,000 but it is 1.5...correct? Is the difference worth it? What about a RAM drive? I am lacking in knowledge on the differences.
Thanks in advance!
-Mav
Thanks in advance!
-Mav
