Xp login problem
How can I remove the login request from my XP PC? This message will disappear with pressing OK.
Thanks for your help.
3 answers Last reply
More about login problem
  1. Click Start> Run and type: control userpasswords2
    Click OK
    The [User Accounts] Property Sheet displays.
    On [Users] tab, clear the [Users must enter a user name and password to use this computer] check box.
    Click [Apply].
    Enter a user name and password that should be used to logon automatically in the dialog box that appears.
    Click [OK].
    Go to [Control Panel] [User Accounts] [Change the Way Users Log On and Off].
    Uncheck [Use the Welcome Screen] and [Use Fast User Switching]
  2. I followed the above suggestion, and now I can't get to my Administrator settings. How I can find my administer password, which I do not remember!
  3. Start windows in the SAFE mode by pressing the F8 key as your computer completes POST and before it boots into windows. Go to control panel and open user accounts, you should be able to change passwords there.
Login Windows XP
