Dolby Advanced Audio V2 missing after factory reset.
  • Laptops
  • Dolby
  • Audio
  • Apps
Last response: in Apps General Discussion
September 11, 2012 10:40:22 PM
I bought a laptop one year ago, an acer 5750g.
It came pre-installed with dolby advanced audio v2.
I recently restore the laptop to its factory settings and restored what files I could from the backup I immediately created after i recieved the laptop. Now there is no dolby interface or dolby sound quality.
My question is can i get dolby back? I cant find any setup packages and the folder which once had the dolby files, Dolby PCEE4, now has only 4 files.
I really need dolby as otherwise the sound quality is atrocious :(
Thanks for all replies,
Sher
More about : dolby advanced audio missing factory reset
September 11, 2012 10:46:22 PM
Forget that I have found the installer it was in the Realtek HD Folder
