hi, this is my spec
- e6300 stock
- stock HS/F
- Corsair value select 2GB 677 (duel channel_)
- foxconn p965
- 470w PSU asaksa (bit small but will do)
- px7600gs leadtek not OC'ed
any way i followed a guide in mag here in the UK bout OC'ing. and im quite knowledgeable in PC's and am on the forum a bit. so i know that my C2D should be able to reach 333mhz without voltage increases.
it failed to post and i had to reset Cmos after a series of long beeps
so what do you think it is i dont want to OC abv 333 but i want it to be stable.
do you think my cheap ram need a voltage increases.
- e6300 stock
- stock HS/F
- foxconn p965
