A number of points you might want to look at.
What is the wattage on your PSU, and how many of what components do you have attached to it?
Also, check the block to make sure it's properly seated on the CPU, and check the thermal gel. With gel, almost nothing goes very far, more doesn't work so well.
Anyone else have any ideas?
