Tom's Hardware Forums » CPU & Components » Sound Cards » Do composite cables carry surround sound signals?
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Do composite cables carry surround sound signals?
Profile: journeyman
More Information
As stated, I am setting up a home theatre system and unfortunately limited to component cable.  These are mono im guessing?  I dont have any other connections to the TV other than S-Video and component.  I was just curious if RCA cables carried all signals.
Core 2 Extreme 2.93GHz Stock
P5N32-SLI SE Deluxe
Corsair TWIN2X2048-6400C4 2GB Kit DDR2-800
EVGA 7900GT KOx2 SLi
Related Pr oduct
Runs with scissors
Profile: addict
More Information
Composite and S-Video do not carry any audio.  Composite consists of RED/GRN/BLU cables and only carries video signals.  It maybe slightly confusing as composite cables and the audio cables both have RCA plugs on them.  You need to hook up the audio RCA cables (typically either RED/YLW or RED/WHT) to get audio from whatever to your TV.  HDMI is the only multi (video/audio) connector that I know of for consumer electronics.
Message edited by techgeek on 10-23-2007 at 06:52:17 AM
Don't go away mad, just go away!
Profile: nimble knuckle
More Information
the red and white rca cables carry stero sound, not mono... ie left and right channels seperately for each cable.
U win some, the rest u smoke
Profile: old hand
More Information
Yeah WTS ^^^
Tho many hifi's can sperate stereo into 5.1
Its not perfect but it will play the correct sounds thru the correct speakers.
Its always better to use a 5.1 coax or better digital (single coax or optical)
Q6600 B3 2.7Ghz @ 1.085v load
4850 + 8800GTS 320
P5B-D
3Gb 800
Add a reply
Google Ads
