I'm in the process of finishing up modding my antec 900 case.....The tower is not hooked up to a monitor, or keyboard/mouse, nor has any OS been installed yet. I was merely checking connections and lighting effects of the UV lights.
The mobo is: GIGABYTE GA-P35-DS3L
The CPU fan is: AC Freezer 7 Pro
which is plugged into the cpu fan on the mobo connection.
When power is first turned on the fan seems to want to rotate, and attempts, but never realy turns more than just a bit, say like if you hand someone holding one of your legs and you tried to walk forward and then was brought back because of the leg being held back. This happens for a bit.....I got worried and turned the system off.
I then pluged the cpu fan into the SYSTEM1 fan connection and when the system is turned back on, the cpu fan starts right up like it should.
I experimented and put the cpu fan back into the CPU connecter, and powered up, and again the same thing, but when I rebooted the system, it waited for a few seconds and then would spin up just fine.....what is this?
Will this all fix itself once I get into the bios and fiddle with the settings? Or is this a indicator that either the mobo or the cpu fan is bad? I would think the fan, though I don't know if I can return the fan, as I've painted part of the cpu fan wire (covered with a sleeve) with UV paint....
Any idea's folks?
Power supply is a Cosair HX520W
Any idea's folks?
